Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
  1. #21
    Nov 2011
    600
    Re: Next best hand held swirl finder succeeding the discontinued Brinkmann dual xenon?
    I picked up a Kobalt Hyper-Coil LED light kit at Lowes this weekend. They are on sale 40% off ($24.99), so I couldn't resist. Seems odd they are on sale since it's a brand new product and they're even advertising it on TV, but I wasn't complaining.
    It has rechargeable Lithium-ion batteries and can also run 3 AA batteries (and also has a 3 year warranty). I used it configured as a flashlight.
    I can only speak to white paint for now, but I compared it to my Brinkman Xenon and also to a 250 lumen Cree LED flashlight. With the right settings the Kobalt actually works better for light scratches on white paint than the Brinkman (the Cree flashlight is the least effective of the 3). The Kobalt actually worked best on the low setting (which they say is 100 lumens, compared to 200 lumens on the high setting), and with the focus just slightly backed off from the narrowest beam.
    The Kobalt is a more blueish-white light compared to the warmer yellow Brinkman xenon.
    Anyway, might be worth a try, given the sale price and 3 year warranty (and also the alternate "snake" neck configuration when used as a work light.
  2. #22
    Super Member BrianMcLeod's Avatar
    May 2013
    812
    I'm sad to have found out they are being discontinued...
    I've been using and showing these since March of 2005 as documented in this article with due credit going to where credit is due...
    Brinkman Maxfire Dual Xenon Rechargeable Spotlight - Review and How-To
    Review
    The Brinkman Xenon Swirl Finder Light is one of the handiest tools ever invented when it comes to removing swirls out of your car's finish.
    I first learned about this specific type of flashlight back in March of 2005 while working as an Instructor for an advanced class on how-to wet-sand paint and then use a rotary buffer to remove sanding marks along with Kevin Brown, another well-known Professional Detailer and Rod Kraft a Field Rep for Meguiar’s and also an accomplished detailer himself. Rod brought the Snap-On Tool version which is harder to obtain for most people.
    A few months later, my good friend and Professional Detailer Joe Fernandez, who goes by the forum nickname SuperiorShine on all the detailing discussion forums, who was also at the Advanced Class in 2005 came by a shop where I was working on a car called the Panic Parrot to show me the Brinkman version of the light Rod had shown us a few months earlier and let me test it out.
    Here’s the car I was working on along with Richard Lin for a how-to video, a 1950 Panic Parrot Starlight Coupe painted candy tangerine with purple flames.
    Because it is a true show car, it had an exceptional finish with only very light swirls but the standard for a show car like this is zero swirls. If you look closely, you can see the tale-tale sign of the Brinkman's dual light bulbs in this shot of the passenger's side fender.
    There were more swirls in the paint on this show car but this is the only picture I have that shows the bulb reflection of the Brinkman that documents how long I've been using this light thanks to Joe. Time Stamp on these pictures go to 6/22/2005 The Swirl Finder light let us know the paint only need light correction work and thus we only used a cleaner/polish with a DA to reach our goal. The Brinkman Swirl Finder Light doesn't have to show gross swirls to be of value, it just has to light up the paint like the sun.
    A must-have tool
    Ever since learning about this flashlight I've incorporated it into all my classes and shared it with the students as a way of inspecting their work as well as using it myself for all the cars I detail to check my own work and progress.
    Showing students how to use the Brinkman Swirl Finder Light
    The Brinkman Xenon Swirl Finder Light duplicates what bright sunlight will do and that's expose swirls so your eyes can more easily see them only with the Brinkman Xenon Dual Bulb Swirl Finder Light you have the convenience of shining the light whenever you want and wherever you want, you have total control. With the sun... well besides having to move the car into the sun you have to hope the sun is actually out in the first place which limits you to summer months for most regions.
    How to pronounce the word Xenon
    First, let me share how to properly pronounce the word Xenon. According to Merriam-Webster's Online Dictionary which has audio files you can play, Xenon is pronounced,
    zee non or ze non
    The first version with a long e and the second version with a short e
    I prefer the long e version.
    (I would include the link to the specific webpage but it tries to open a pop-up window, so I'll let you Google it on your own)
    Dual Xenon Bulbs
    The feature that I like the most about the Brinkman Swirl Finder Light is that is uses special Xenon bulbs to shine intense light on paint imperfections which enables your eyes to more easily see swirls and other defects. A car's paint finish can look great in the shade or indoors but under the intense scrutiny of the swirl finder light, all of the imperfections are revealed. With the ability to see everything in the paint clearly, I can select the correct polisher, pad and swirl remover to polish the paint to perfection.
    The power of the sun in your hand
    The Brinkman Swirl Finder Light shows swirls in much the same way the sun shows swirls only you don't need to move your car into the sun in order to see the swirls, instead you simply pull the trigger on gun-style flashlight and light up the paint while inside your garage or detail shop.
    A must have tool for your detailing arsenal
    The Brinkman Swirl Finder Light is one of the most valuable tools you can own and every detailer and serious car enthusiast should have in their arsenal.
    Saves time
    For enthusiast and pro detailers, you can use the light to gauge your polishing progress instead of spending valuable time moving a car in and out of the garage just to check your work.
    Winter, cloudy or overcast day
    If it's cloudy outside or the middle of winter when the sun isn't high overhead, (where it needs to be in order to shine down on the horizontal panels), the Brinkman Swirl Finder light takes the place of the sun and gets the job done.
    Vertical Panels
    When you're working on vertical panels it's not realistic to try to move your car around to position it in such a way as to reveal the swirls. The Brinkman Swirl Finder Light is invaluable when checking your work or showing a customer the true condition of their car's paint.
    Switch between one bulb or two bulbs with a flick of a switch
    Two powerful Xenon bulbs produce a high intensity beam of light so you can easily spot imperfections. The Brinkman Swirl Finder Light easily adjusts from one beam to two beams to increase or decrease the brightness.
    Rechargeable Battery - 120 Volt and 12 Volt
    The Brinkman Swirl Finder Light uses a rechargeable Ni-Cd battery and includes both a 120-volt AC charger for wall outlets and a 12-volt DC charger/adapter for charging it from the cigarette lighter in your vehicle. The car charger enables Mobile detailers to keep the light charged while driving to the next job. A LED indicator glows red when the battery is charging and goes off after full charge is reached.
    Rugged design
    The Brinkman Swirl Finder Light is built out of rugged ABS plastic with a pistol grip handle. It has a metal swivel hook to enable you to hang it up inside your garage or inside your detailing rig.
    The Brinkman Swirl Finder Light is ideal for anyone who details for pleasure or profit but for professionals in particular, this light is a small investment which enables you to show your customers you’ve completely removed all imperfections. This demonstrates you are a knowledgeable professional and builds confidence in your clientele for repeat work as well as referrals.
    Features:
    • Constructed of tough ABS plastic with a pistol grip handle
    • Easily switches from one beam to two beams to increase or decrease the brightness
    • ON/OFF trigger switch for momentary bursts of light
    • Lock button for extended ON times
    • LED indicator that turns off automatically when fully charged
    • Convenient metal bracket for hanging or storage
    • 120-volt AC charger that operates from a standard wall outlet
    • 12-volt DC charger/adapter for recharging from a cigarette light receptacle
    • 1 YEAR WARRANTY
    • Owner's manual
    How to use the Brinkman Swirl Finder Light
    Using the Brinkman Swirl Finder Light is pretty straightforward but here's a few tips to get the best results when exposing swirls.
    You want to hold the Brinkman Swirl Finder Light about 12" to 16" away from the surface you're inspecting and hold it at an angle so that the light bounces back to your eyes.
    Correct distance to hold the light from the finish
    Swirls in the clear coat finish surrounding the dual Xenon light bulbs
    Correct hand position when inspecting for swirls - Comfortable, ergonomic grip
    What's in the package?
    Frontview
    Backview
    Out of the package
    Charging instruction (in the included manual)
    First things first - Fully charge after removing from package
    After you remove the light from the packaging, the first thing you want to do is charge the battery until the light goes off, this may take up to 8 hours but less than 12 hours. Don't leave it plugged in longer than 12 hours per manufactures instructions.
    When the battery is low on charge, a red light will glow after the charger is plugged into either a wall socket or a cigarette lighter in your car.
    Red light indicates the battery is charging
    Plugged into cigarette lighter
    Bonus!
    Besides being a great light for exposing and highlighting swirls, it's also handy as a flashlight for around the house, in the car or on a camping trip.
    Tip for detailers...
    Always be prepared to win a new customer
    I keep a fully charged Brinkman Swirl Finder Light in all vehicles just in case I run into someone that thinks their car is finished when we detailers know that the frosting on the cake is a swirl-free finish. With a Brinkman Swirl Finder Light you can quickly and easily show a potential customer the problem with the paint on their car.
    Not only will the Brinkman Swirl Finder Light enable you to show a potential customer the problem, but will instantly become a topic of curiosity in and of itself and show the potential customer you're serious about your craft.
    Don't leave home without it!
    I can't even begin to count how many cars I've inspected with this tool nor how many people I've introduded to it since learning of it myself 9 years ago...
    I was about to buy one this week do y'all have any I could buy?
    Like my page on facebook ill like back - https://www.facebook.com/pages/Brian...668?fref=photo
  3. #23
    May 2013
    812
    I also know where there's a collection of Brinkmann Swirl Finder Lights, all in brand new condition that have been signed by the Swirl Girls...
    Kristin autographing the Brinkmann Swirl Finder Light...
    I was about to buy one this week can I still buy it? The sign ones?
  4. #24
    Super Member aim4squirrels's Avatar
    Nov 2013
    DFW Texas
    1,078
    Quote Originally Posted by BrianMcLeod View Post
    Would also like to know this as well. Autogeek lists "Backorder"
    when you click the link to their webpage.
  5. #25
    Super Member CriticalDetails's Avatar
    Mar 2010
    St Albans, Vermont
    296
    Quote Originally Posted by creaky View Post
    I am curious about this topic, particularly the xenon vs LED issue. In a previous post Mike stated that xenon was superior for finding swirls. However, many use LED and praise them. Further, the number of lumens, some have stated, should not exceed about 300 as the reflection off the paint should not be so bright as to contract the pupil and hinder one's ability to inspect the paint. Please chime in with experiences.
    Very good information. I use a 277 lumen Fenix HP11 LED headlamp for all of my correction work. The HP11 has four different levels of light output and I use level three and four for correction work. You can buy an LED headlamp or flashlight brighter than 300 lumens but I wouldn't use it on the max setting all of the time. After performing a multiple step paint correction I occasionally suffer from some eye strain.
    You may even want to look at the Fenix HP15 LED headlamp. The HP15 is a new model and there aren't many reviews yet. However Fenix makes a quality product and I wouldn't hesitate to buy another LED headlamp/flashlight.
    Be sure to buy a bunch of rechargeable AA batteries. I have twelve rechargeable AA batteries that I change throughout the detail.
    Critical Details
    Trevor Spedden
  6. #26
    Super Member spiralout462's Avatar
    Dec 2012
    Eastern Shore, VA
    1,771
    Quote Originally Posted by Billy B View Post
    Has anyone tried out the 3m sun gun? Would it be a good replacememt
    Sent from my SAMSUNG-SGH-I337 using AG Online
    That is much more expensive right? There are threads around here where members made their own "Sun Guns" out of old cordless drills. Pretty interesting stuff!!
  7. #27
    Junior Member Billy B's Avatar
    Nov 2010
    95
    Quote Originally Posted by spiralout462 View Post
    Yes. They're quite a bit more expensive than the Brinkman. Ive also seen a few DIY light threads. Im confident somebody will come up with something newer and better. Innovation
  8. #28
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    ^^^Color matching/Color correcting lamps (Sun Guns)^^^
    are excellent swirl-finding tools!!!
    ^^^I've seen the 3M Sun Gun II Kit...for as low as $475.00^^^
    ^^^Thanks for the plug!^^^
    ^^^IMHO: Nothing beats Sun Guns/Sun Guns' Solex lamps!^^^
    http://www.autogeekonline.net/forum/...nder-30-a.html
    Per:Wills.WindowsAndWheels Request...My Version of a "Sun Gun"... / http://www.autogeekonline.net/forum/...hp?albumid=344
  9. #29
    Jul 2013
    Soo Fenix would be the next best thing?
  10. #30
    May 2013
    812
    Quote Originally Posted by SR99 View Post
    Got the light tonight and it works!! On blue/ gray paint brown/green and red!!
  1. Brinkmann Dual Xenon or ? for swirls
    By bcgreen in forum Auto Detailing 101
    Last Post: 09-21-2020, 03:57 PM
  2. Opinions on hand held swirl finder
    Last Post: 10-08-2012, 12:22 AM
  3. Brinkmann dual Xenon vs. Blackfire
    By walletless in forum Auto Detailing 101
    Last Post: 04-09-2012, 07:12 PM
  4. Brinkmann Tuff Max Dual LED or Dual Xenon?
    By veeko in forum Auto Detailing 101
    Last Post: 09-29-2010, 04:04 PM
  5. NEW- Brinkmann Tuff Max Dual LED Swirl Finder Spotlight
    Last Post: 07-16-2010, 11:11 AM
