Noobie Needing Compound/Polish Product Advice
Hi everyone, first post here.
I own a 2012 VW GTI, white, and I will be looking to do my first machine polish in the spring. So, I am doing my research now.
We have pretty harsh winters here with lots of snow, sand, gravel, and salt.
My plan is to do a 2 bucket wash, clay (it will need it), but then this is where I get lost. The car has some very light scratches in a few places and some water spots. I was looking at the poorboy product line as I don't want to spend a ton on product for my first attempt... once I get better I am sure I will bite on some fancy stuff.
I was looking at the chart here on AutoGeek and guessed the following: (Autogeek Swirl Removers & Compounds Comparison Chart)
Wash
Clay
Poorboy SSR 2.5 (Orange or white pad, will test white first)
Poorboy Polish With Sealant
Wax (I will likely go with Meguiar's NXT, as I have used it in the past).
So my big question is, is it correct to go from the SSR 2.5 to the Polish with sealant? I really want a wax over a sealant so as to provide maximum protection as I park outside and the environment is pretty harsh here. Do I need to add another step as kind of a less aggressive polishing step?
Let me know your thoughts, and thanks!
Re: Noobie Needing Compound/Polish Product Advice
Wash
Clay
Compound
finishing polish
IPA wipe down or Top inspection
sealant
wax
Excellent. Which products of poorboy's do you think would best work for this situation? (Of course you will never know unless you see the car... but as a best guess?)
I just don't understand which products of theirs are compounds, polishes, sealants and waxes.
The SSR1 sounds like a 2 in 1 polish and sealant.
That's the one product I have never tried
Welcome to the forum....
Might be easier to get Pinnacle The secret to the combo is to use the Pinnacle Advanced Swirl Remover (ASR) first, followed by the Pinnacle Advanced Finishing Polish (AFP). or Wolfgang twins Wolfgang 8 oz. Swirl Remover Combo, Wolfgang polishes, total swirl remover, finishing glaze, machine glaze
Poorboys starts at 3(most aggressive swirl remover, compound) then 2.5, 2, 1 (least aggressive)
Polish with sealant (PWS)
Depending how bad the finish is with swirls, micromarring, etc. Pad choice will be important too.
I'm sure you've read a lot, http://www.autogeekonline.net/forum/...-phillips.html
Good luck
I have sample sizes of all 4 Poorboys if you want them, n/c!!
Interesting stuff. I will likely go with the pinnacle solution. I just wasn't sure which polish I should follow up the swirl correction with.
Thank You!
I have two candy white golfs a 2 door R and a 4 door tdi. If they are swirled or scratched I recommend menzerna 2500 and for rids 400... I follow both up with 4500 and you will be amazed at how much gloss you can get from candy white. I have no experience with poor boys but I can tell you I tried pinnicale advanced swirl remover and while this removed light swirls still left deeper swirls (hydro tech pads and pc were used) vw candy white is harder than you would think... Just my experience every cars different both mine have the same June build date for my12 so makes sense the paint is the same for both.
Best of luck after I got both mine to my liking I opticoated them and topped with reload.
I also recommend using a standup 600w shop light will greatly improve ur ability to catch rids and swirls...
Mine were a pita... So I wish u the best!
(Swirls came from the dealer I was deployed when my wife took delivery and while she's trained well in washing refused to be pushy with the dealer and be there for the unwrapping... Oh well she supports the detailing sickness..)
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government" Thomas Jefferson,
to AGO
To Autogeek Online!!
Poorboy's World offers some superb products that not only work, they work very well. If you'd like to stay with their line theses should please you
Wash - Poorboy's World Wash
Clay - Meguiar’s Clay
Compound - Poorboy's World SSR3
Medium Polish - Poorboy's World SSR2
Finishing Polish - Poorboy's World SSR1
Sealant - Poorboy's World EX-P Sealant
Wax - Collinite 845
Foam Polishing Pads
Yellow Cutting 5.5 inch Foam Pad - Use this pad to apply compounds or polishes to remove severe oxidation, swirls, and scratches. It is the most aggressive and should only be used on oxidized and older finishes. Always follow this pad with an orange or white pad and a fine polish to refine the paint until it is smooth.
Orange Light Cutting 5.5 inch Foam Pad - Firm, high density foam for scratch and defect removal. Use this pad with polishes and swirl removers. It’s an all around pad that will work on most light to moderate imperfections.
White Polishing 5.5 inch Foam Pad - Less dense foam formula for the application of waxes, micro-fine polishes and sealants. This pad has very light cutting power so its perfect for pre-wax cleaners.
Gray Finishing 5.5 inch Foam Pad - Composition is firm enough to withstand added pressure during final finishing to remove buffer swirls. It has no cut and will apply thin, even coats of waxes, sealants, and glazes.
Blue Finessing 5.5 inch Foam Pad – Flat pad has soft composition for applying glaze, finishing polish, sealants, and liquid waxes. Flat pad provides full contact with paint surface to minimize the pressure applied by the user.
I was looking at the chart here on AutoGeek and guessed the following: ( Autogeek Swirl Removers & Compounds Comparison Chart)
Wash
Clay
You have a special vehicle. I am sure you knew this already but it goes deeper.
VW's typically have ceramic clear coats (ceramiclear); very hard clear coats. For the time and effort savings alone you should go with Menzerna polishes. I have no experience with Poorboys but I have used Meguiars M205 and M105, and Wolfgang TSR on my 2012 VW CC. Using orange/white pads they could not remove the fine swirling I saw on my panels; and I have Flex 3401 to boot! I still remember applying a lot of pressure. It is funny in retrospect. Menzerna, removed them with ease!!!! Here is an approximate breakdown of products.
IS-4000 - Medium Polish
PF-2500 - As close to an AIO as you can get with Menzerna
With your description of the paint condition I'd try out PF-2500 first; and with a flat polishing pad. The intention would be to get "at least" (conservatively speaking) 85% correction with this one product. If you need deeper treatment on some panels/spots then IS-4000 with a polishing or cutting pad followed-up with PF-2500 (polishing pad) should do the trick.
NOTE: Once you end up with PF-2500 on the vehicle you can do another pass with light/finishing polish pad but that's only if you see a difference in look and/or feel. This last part may be overkill but for the OCD people out there, this may work out for you.
With these 2 Menzerna products you eliminate both PB products and NXT. The reason you eliminate NXT is because there are cleaners in NXT and you wouldn't want to eliminate anything PF-2500 left you. In theory, you could apply NXT with a wax pad, or any pad that has zero cut. That would give you the sealant properties to lock-in the gloss. If you will replace NXT, then in it's place you get a pure sealant or wax. Collinite 845 will serve you well as an LSP since it is a very cost effect sealant/wax and will give you at least 4-5 months of protection.
Best of luck!
By Halon in forum Auto Detailing 101
Last Post: 07-08-2020, 09:10 AM
By Boejoula in forum Auto Detailing 101
Last Post: 12-12-2015, 11:38 AM
By Siciliang35 in forum Tricks, Tips and Techniques
Last Post: 05-05-2015, 07:53 AM
By topnos in forum Auto Detailing 101
Last Post: 04-25-2013, 07:20 AM
By Anto in forum Auto Detailing 101
Last Post: 06-14-2008, 09:33 AM
