» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 10-26-2012, 01:08 AM   #11
Optimum Product Support
Chris@Optimum's Avatar
Re: Optimum MF Pads
Quote:
Originally Posted by SSizzlin' View Post
Good luck keeping the pad rotating with a decent amount of pressure on speed 4 with the PCXP.
With the face of the pad primed, cleaning or changing the pad as needed, and not using a big pad to cut (on the PC) it should do fine. Mark the backing plate for reference and straighten up or lighten up if it stops moving. If it needs more correcting than that gives either work on technique or buy a forced rotation machine.
Most times I see these pads stop rotating is when there's too much product and all the fibers are matted down. Or they have removed a lot of paint and need to be blown out or brushed or both.
Most people that have questions for me about any given product are looking for definitive answers. For example, they would like to hear: use x polisher with x pad for x minutes on x speed and no matter your skill level or paint system, you wil have perfect paint. That never happens because of variables like aggressiveness of product/pad, hardness of paint system, consistency of appropriate pressure, humidity, heat, machine, skill, etc. Combinations of variables will range in hundreds of results just changing a couple of variables.
I said all that to make the point that it just takes awhile to learn "how" to use a product...but more importantly it takes time to be able to recognize what is actually happening and adjust your technique accordingly. That is why some people can produce stellar results with OTC products and discount polishers and also why the most anal do it yourselfer can sometimes have all the best products and equipment money can buy and not get good results. It just takes time behind the wheel with each new thing you try. Microfiber pads work differently than foam so you have to learn them.
Have confidence it yourself and the product. Know that we already spent the time, money, and effort making sure hey work before we release them to the public. And thankfully there is a great place like AG where u can find others having good results and ask for help.
__________________
Chris@Optimum is offline
Old 10-26-2012, 05:40 AM   #12
FivePoint.0's Avatar
For the record, I'm not referring to just OPT MF pads and the PCXP. I'm talking about any pad on speed 4 with the PCXP. IME, on speed 4, the tool is flat out weak! There's noticeably more power on speed 5 and 6, though.
__________________
Mark
'08 Nissan 350Z Enthusiast Coupe - Carbon Silver Metallic, 6MT
FivePoint.0 is online now
Old 10-26-2012, 06:36 AM   #13
Vegas Transplant's Avatar
Re: Optimum MF Pads
I agree with SSizzlin' on this point.
Those that turn speed 4 on the PC - kudos to you for your success.
Just doesn't happen for me.
Speed 5, and changing out pads frequently works in my favor.
Quote:
Originally Posted by Chris@Optimum View Post
...Combinations of variables will range in hundreds of results just changing a couple of variables.
...I said all that to make the point that it just takes awhile to learn "how" to use a product...but more importantly it takes time to be able to recognize what is actually happening and adjust your technique accordingly.
...Microfiber pads work differently than foam so you have to learn them.
...Have confidence it yourself and the product. Know that we already spent the time, money, and effort making sure hey work before we release them to the public.
My experience with mf pads has truly been an educational process, and I'm on cloud 9.
I have learned much and appreciate not only the process, but the results.
I pretty much know which machine (PC or Makita), and product, or combination of product to reach for to begin the test spot on nearly every vehicle I touch with mf.
__________________
Me and you, your mama and your cousin too...Rollin down the strip on Vogues~Comin up slammin Cadillac do's... VT
Vegas Transplant is offline
Old 10-26-2012, 06:38 AM   #14
Kool!
__________________
Mark
Old 10-26-2012, 02:41 PM   #15
Member
I would have to agree on speed 4 on the PCXP. But great info and I will try all that on my next go around. I did have a lot of compounding to do, deep water marks. Most are still there as I didn't want to go too far. Thanks Chris for the update and I will try those settings. I have been doing slow arm speed and various levels of pressure. Sped it up in order ro keep pad turning. It may e too mch product as it was matted down on pad
us6krums is offline
Old 10-26-2012, 02:42 PM   #16
After you polish a section, it's normal for polish to be matted on the pad. The optimum sprays don't do that as much, but it's normal with traditional polishes.
__________________
Mark
Old 10-26-2012, 03:38 PM   #17
DRT BRD's Avatar
Re: Optimum MF Pads
Quote:
Originally Posted by swanicyouth View Post
Maybe too much polish and too high speed created too much heat? I have Compound II, but have yet to have a need to use it. I've used Polish II and Finish Polish without any dust or issues. I'd have to agree that maxing the machine out at 6 is too high for constant use. I never go above speed 5 and I'm using an original 7424.
Try slower arm speed. If you are polishing half a hood that is about 18" long, count : one one thousand, two one thousand, etc... Until you reach 18. Then you can see how slow an inch a second is. It's really slow.
Speed 5 on the orginal PC is around 4800 opm. So you would do setting 5 for cutting and 4 for waxing etc. On the XP it's 4 for cutting and 3 for waxing.
Quote:
Let the machine and product do the work. If anything try 4.5 and work through it. Less is more sometimes and I have no problems with mine. Technique folks.
__________________
Brian's Custom Detailing
Where detail matters
www.BriansCustomDetailing.com
DRT BRD is online now
Old 10-26-2012, 05:57 PM   #18
vegas911gts's Avatar
Re: Optimum MF Pads
What speed should I be using with the optimum mf pads for a flex 3401? I have 2 sets of each type of pad but haven't used them yet. I'd like to try it out next month when I give my car the last real wash, clay, polish, sealant, and wax before winter.
vegas911gts is online now
Old 10-26-2012, 07:49 PM   #19
Capa1970's Avatar
I destroyed two Optimum mf pads (first use) just on the hood of my car. I used a Griot's and speed 5 and switched pads per section. I had separation on one pad and the other pad on the back showed evidence of light melting and part of it was black. I was using D300. I was very disappointed but apparently the machine should of been on speed 4 (which on a Meg's isn't enough and on a Griot's does not seem to be enough).
Capa1970 is offline
Old 10-26-2012, 08:25 PM   #20
Johny B's Avatar
Re: Optimum MF Pads
+1
Johny
Johny B is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
*NEW* Lake Country Ultra-Fiber Microfiber Pads! Nick@Autogeek New Car Care Products 43 08-22-2012 10:07 AM
Which pads and products for my new DA? TechDiver Questions about the Porter Cable 7424XP, 7424, 7336, Griot's and Meguiar's Dual Action Polishers 2 07-25-2012 05:17 PM
Reviewed: Optimum G-P-S mikep288 Product Reviews 32 01-11-2012 04:12 PM
Optimum compounds and polishes, which pads? 05RLS2 Products Guides 7 07-23-2011 09:42 PM
Optimum Hyper Polish & Hyper Compound Anthony Orosco New Car Care Products 24 04-25-2010 04:42 PM
» May 2013
» Car Care Brands
