» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 10-18-2012, 02:10 PM   #1
maxdetail's Avatar
clay bar storage
Hi!! I've been using Ricardo yellow clay for 1 year and found that it is not lasting long enought. 1 caly bar cut in 3 the little piece last about 3-4 vehicules before it disintegrate to small bits. I'm thinking this clay bar does not like the heat to much?? It's stored it in it's plastic case in a drawer in the garage. Mabe it's not liking the CG maxi-sudsII I use for lube???
__________________
Max Detail
maxdetail is offline
Old 10-18-2012, 02:19 PM   #2
Twister's Avatar
Some lubes will cause the clay to fall apart quicker. I quit using soap and water mixture and started using products like ONR, UWW+ or a dedicated clay lube
Twister is offline
Old 10-18-2012, 04:33 PM   #3
maxdetail's Avatar
Re: clay bar storage
Quote:
Thanks for you input!
__________________
Max Detail
Old 10-18-2012, 07:46 PM   #4
I have been using the same bar of Riccardo Blue clay for almost 3 years now! i keep it in a air tight jar with a spray of ONR on it.
Chesniak is offline
Old 10-18-2012, 09:05 PM   #5
maxdetail's Avatar
Quote:
WOW!! I had never really look at ONR before because the cars I get to clean are usualy extremly dirty. Now that I have read up on it I am definitly getting some thanks.
__________________
Max Detail
Old 10-20-2012, 07:32 PM   #6
I keep mine in a zip lock bag with spray detailer on it to keep it moist. I just replaced one after almost 2 years. I end up replacing them due to being dirty and not falling apart.
__________________
2003 Ford Lightning #3836
2011 BMW 335i coupe
slapshot is offline
Old 10-20-2012, 09:36 PM   #7
Capa1970's Avatar
My griot's clay started to fall apart (almost disintegrate) after a year of use. At first I assumed it was because I had tried Griot's waterless wash but then the next time I switched to UWW+ and the disintegration continues
The clay is kept indoors in Griot's clay can and I always spray it with some sort of quick detailer. The clay is now two years old.
Capa1970 is offline
Old 10-22-2012, 07:35 AM   #8
lawrenceSA's Avatar
I use ONR as a lube, and once done claying spritz some onto the clay and close in a airtight container. Have had no issues to date
lawrenceSA is online now
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
car pro iron X or Clay Bar zas Auto Detailing University 20 07-19-2011 01:25 PM
what is needed? dX 412 Ask the Expert featuring Mike Phillips 17 04-07-2011 11:02 AM
When to use Aggressive Clay Bar?? Sellncars Ask the Expert featuring Mike Phillips 1 04-18-2010 03:16 PM
The Linguistics of the Clay Bar: It's Time to Correct our Spelling akimel Off-Topic 9 01-31-2009 10:38 PM
*Pinnacle Poly Clay Bars Jason Pinnacle Wax 15 02-27-2008 06:31 PM
» May 2013
» Car Care Brands
