Hello everyone, today I wanted to try an experiment. I wanted to see how well Solution Finish would work in pretty extreme conditions.
What do I mean by extreme conditions? (glad you asked)
- No preperation was done. No cleaning. No detail spray. Nada
- Not only the above, but Solution Finish was applied on top of old wax stains.
- No extra care will be given to treated surfaces.
- Florida sun, heat, and rain.
- Applicator was a cheap microfiber applicator from Walmart.
The big thing here was that there was no prep and it went over the wax stains. I did NOT wash my car (you will be able to tell in the pictures :P), nor did I clean in any way the trim.
I also applied the Solution Finish ON TOP of old wax stains from when I was more of a newbie at washing and waxing.
So... let's see how long this lasts. At 30 dollars an ounce, I will be disappointed if it doesn't last 4 to 6 months, regardless of the fact that it was applied in extreme conditions.
Application was done with a circular microfiber cheap piece of junk from walmart.
We shall see the results in the coming months. I will update.
Note: Please ignore the damage to the bumper, I bought my car used, and someone apparently didn't have a big enough garage
Starting condition:
Only used it on the bottom grill. Applied on right, not applied on left.
Close up
Close up of applied side:
Closer close up of applied side:
Non-applied side close up:
Non-applied side closer close up:
Other angles
Close up of middle
Far away shot:
Product:
Solution Finish Black Plastic & Vinyl Restorer, trim restorer, black plastic restorer
