» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 10-13-2012, 07:58 PM   #11
ihaveacamaro's Avatar
Re: Solution Finish Review Durability in Extreme Conditions
Quote:
Originally Posted by TroyScherer View Post
This I can agree with... I like the thought out plan.
Thanks, I hope I got some people real curious. I know I'm generally a very curious guy by nature, so I can't wait to update the results every week or two
ihaveacamaro is offline
Old 10-13-2012, 08:05 PM   #12
Wonder how this compares to the offering by 3M Bondo for $9.99?
__________________
rwright is offline
Old 10-13-2012, 08:19 PM   #13
Quote:
Hmmm might make a good Thrifty vs Fifty thread. I also am wondering about Chemical Guys Gel Black Forever Trim and Tire as I have seen people recommend that.
Both could go against Solution Finish as a Thrifty option. Although, that would have to be a thread and not a video as it would be over a long period of time.
Interesting ideas
Old 10-13-2012, 08:53 PM   #14
FUNX725's Avatar
Quote:
-I'm generally a very curious guy by nature, also!!
-Which has caused me to be real curious of your:
"Curious(<<odd)-Solution Finish-Experiment".
-So...After carefully reading through your postings regarding this matter
(with an open-mindness it deserved)...
-I have concluded that this is a "skewed-experiment", in so many ways, that it has:
'Fail'
written all over it.
If this fails,
JMHO...
__________________
Be wary of the man who urges an action in which he himself incurs no risk~Joaquin de Setanti
FUNX725 is online now
Old 10-13-2012, 09:20 PM   #15
'Fail'
JMHO...
If it fails, I will have learned something. By learning something, it has not failed my curiosity.
As I said before, this is not a true test of the potential of the product. This is just to see what this product can do with no prep.
Old 10-13-2012, 09:25 PM   #16
davidc's Avatar
In my case it lasted 4 days with prep on the back step pad of a Toyota Sienna. 303 buffed in with a rotary lasted 3 weeks.
Dave
davidc is offline
Old 10-13-2012, 09:37 PM   #17
Quote:
Dave
Is your trim smooth or textured?
Old 10-13-2012, 09:45 PM   #18
davidc's Avatar
Smooth and it is not a hard plastic. Kind of a cross maybe of plastic and rubber since it is a step pad ?. I have given up on it for now and it is completely gray again. I have tried UTTG, Dlux, 303 and DG 253. Surprisingly 303 and DG outlasted the pricey stuff.
Dave
davidc is offline
Old 10-13-2012, 10:15 PM   #19
Quote:
Originally Posted by swanicyouth View Post
This should be good. I bought this stuff to use on some smooth black plastic and it washed right off. I did all the prep, even took the parts off and scrubbed them in alcohol solution and blew them dry.
Even though the product isn't labeled this way, I'm thinking the plastic needs some texture to it for the product to hold up. Unfortunately, I don't have any plastic like that that needs restoring. Looking forward to your results.
Dave
I asked you because I noticed the only other person that also had problems with SF had SMOOTH plastic.
Maybe Solution Finish doesn't work well on smooth plastic??
Old 10-14-2012, 11:07 AM   #20
FUNX725's Avatar
Per your thread-starter title (w/my hightlighting):
Re: "Solution Finish Review Durability in Extreme Conditions"
Is one of the reasons for my posting:
-I have concluded that this is a "skewed-experiment"...
Because I personally don't 'see' the "Extreme Conditions" you set forth in your below postings:
What do I mean by extreme conditions? (glad you asked)
  • No preperation was done. No cleaning. No detail spray. Nada
  • Not only the above, but Solution Finish was applied on top of old wax stains.
  • No extra care will be given to treated surfaces.
  • Florida sun, heat, and rain.
  • Applicator was a cheap microfiber applicator from Walmart.
The big thing here was that there was no prep and it went over the wax stains.
I also applied the Solution Finish ON TOP of old wax stains from when I was more of a newbie at washing and waxing.
-You seem to be putting a lot of stress on "wax-factors" as being one of the "extreme conditions".
-But...As I was alluding to earlier: IMHO...Wax(es)?: Not an "extreme condition"...
-Why do I think so?
TO WIT:
Quote:
Originally Posted by SolutionFinish View Post
Because Solution Finish is a solvent-based product it will cut through most waxes...
...Cw
-As such:
Wax(es), or any of the other 'uncleaned'-contaminates that were existant:
pre-Solution Finish application...then, shouldn’t be too problematic for Solution Finish to: "Cut through".
-One other "extreme condition" you state is:
Only used it on the bottom grill.
-UV's harmful rays will eventually degrade, to certain-varying/degrees, almost everything
under the Sun(<<pun?)...including Solution Finish.
You must also think so as well:
[*]Florida sun, heat, and rain.
-Is this why you are somewhat 'hiding' Solution Finish:
"under the proverbial bushel"?
Let There Be Light!! I say.
I concede:
-Yes!...Just as the Curies set up their own experiment and its parameters...
This your experiment.
But whereas their experimentation was into: "the unknown"; yours, on the otherhand, has known-parameters
that you have either overlooked or blatantly left out of the equation.
Therefore...
Just as the Curies, themselves, were interred prematurely...
...(though their discoveries live on even 'til today!)...
I would not be predisposed of having your experiment reach a similar fate.
JMHO...
__________________
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
How To - Finish Kare Paint Contamination Removal System Mike.Phillips@Autogeek How to Articles 7 05-22-2013 12:55 PM
Review and Extreme Testing: Opti-Coat 2.0 and CQuartz CEE DOG Product Reviews 333 05-15-2013 10:20 AM
Finish Kare #425 Review JCruiza120 Product Reviews 35 10-30-2010 11:26 PM
EXTREME ENOUGH turning 16 yrs old Charcoal paint to Mirror Finish, newbie on rotary kc's Show N' Shine 9 08-01-2010 11:47 AM
Decontaminating my white Cobalt... cobalt9123 Ask the Expert featuring Mike Phillips 7 05-10-2010 11:34 AM
» May 2013
» Car Care Brands
