» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 10-09-2012, 09:33 PM   #1
Best Combo
Hello all.
I am somewhat of a newcomer so please bear with me.
First things first: it’s good to make your acquaintance. Heard this was the place to come for all things detailing so I wanted to reach out.
Just picked up a '00 BMW 540i. Paint is in above average condition, but not stellar. It gives all the indications of a weekend washer who threw a quick coat of carnauba on every season and prob parked in the garage every PM. Nothing drastic, just swirls from casual hand washing/waxing techniques and minor to moderate scratches from usage as a DD.
I will be taking a rotary to it eventually and was wondering what product combo do you recommend to accomplish the following while working w/the BMW's "hard" paint:
(a.)clean up 2000-2500 WS marks from scratch removal
while at the same time
(b.)then remove the swirls I won't be WS on the rest of the car
Thinking maybe M105 followed by a 4or5 and a 2 polish (according to this chart: http://www.auto-geek.net/charts/wax-chart.pdf) to remove ws scratches and then just a 4or5 followed by a 2 for the swirls on the rest of the car. Are there any 6or7 and a 2 combos for removing both ws scratches and swirls, thus skipping the m105? I have a standard variety of pads i'll be working with.
Still uncertain even after quite a bit of research.
Any input, info, wisdom is much obliged, so thanks ahead of time!
MattyL is offline
Old 10-09-2012, 11:04 PM   #2
Evan.J's Avatar
Re: Best Combo
Well if you have sanding marks from 2000-2500 grit you will want to use M105 with a wool pad to remove those marks. Once that is done follow up with M205 finishing polish with a foam polishing pad to refine any mirco marring or holograms that may still be in the clear from the cutting process.
Once that is done you can option for something like M07 Show car glaze or just add your choice of wax.
Evan.J is online now
Old 10-10-2012, 02:21 PM   #3
Re: Best Combo
[QUOTE=Thoryamaha919;749137]Well if you have sanding marks from 2000-2500 grit you will want to use M105 with a wool pad to remove those marks. Once that is done follow up with M205 finishing polish with a foam polishing pad to refine any mirco marring or holograms that may still be in the clear from the cutting process.
Thanks for the reply Thor.
Prob going w/105/205 combo for the ws marring, but what about swirl removal on areas not being ws? Being a compound, 105 seems like overkill for the swirls yet 205 seems a little under-powered with it being a finishing polish. Looking for that happy medium.
So do you recommend a particular polish for tackling the swirls on the bimmer's paint?
MattyL is offline
Old 10-10-2012, 02:42 PM   #4
Divine Details's Avatar
Re: Best Combo
Try some Menzerna sf4000(106fa) instead of the 205. Menzerna polishes give unbeatable shine imo.
Good luck
Divine Details is online now
Old 10-10-2012, 03:01 PM   #5
Member
Re: Best Combo
M105 + M205 will work in just about every situation.
M105 is great. It will work on the tough stuff as well as the swirl marks. Just don't use as much pressure or speed on the areas that don't need much work. I find that M205 alone doesn't do all that much. It will clean up the surface very well and get rid of micro-imperfections leaving a nice glossy finish... but if there are visible swirls and holograms and tiny scratches, you want to go with the 105 and then the 205. Whenever I try just using 205 on a car with swirls and such, I end up going back over a second time with 105 and then coming back a 3rd time with 205 all over again. save yourself the hassle and start with 105. My Volkswagen has pretty hard paint. It laughs at me in German when I try to use 205 alone. If BMW paint is at all like VW paint, 205 won't cut it.
WickedLou9 is offline
Old 10-10-2012, 03:18 PM   #6
smack's Avatar
Re: Best Combo
First off what color is the BMW? Also do you have a D/A? If so I wouldnt use the rotory at all but on the sanding marks. For the rest of the car I think a mf disc with compound will be enough to tackle just about any swirl or defect in the paint.
__________________
Practice dosent make perfect, the dedication to achieve pefection makes perfect. "Smack" (aka Mike)
smack is offline
Old 10-10-2012, 03:27 PM   #7
Waxy's Avatar
Re: Best Combo
Wash - any good car shampoo
clay - Mother's clay bar kit
polish - Menzerna SIP IS-1500
finishing polish - Menzerna Ultimate Finish UF-4500
seal/protect - Blackfire Wet Diamond/Midnight Sun
Quick detailer - Finish Kare 425
Waxy is offline
Old 10-10-2012, 05:17 PM   #8
SON1C's Avatar
Re: Best Combo
wash
clay
105 cyan pad
205 tangerine pad
sealant
wax
__________________
SON1C is offline
Old 10-10-2012, 05:41 PM   #9
detailgod's Avatar
Re: Best Combo
Since you stated you gonna attack it with a rotary i am just guessing you already have some products on hand. If so what products do you already have? And do you jave a DA?
detailgod is offline
Old 10-10-2012, 09:19 PM   #10
Re: Best Combo
Quote:
Just picked up DA and rotary. Honing skills on old mustang fender I have laying around.
Bimmer is Anthracite Metallic.Beautiful color, just begging to shine!
So you recommend going w/ the compound for the rest of the car also. Would you do this on softer paint or just b/c of this being BMW paint?
MattyL is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
List your favorite Pad and Polish combo, and why sportscarhiatus Auto Detailing 101 10 03-08-2012 05:16 AM
Optimum Hyper Compound/Polish Spray Combo Question. SupraTurbo94 Ask the Expert featuring Mike Phillips 2 08-30-2010 07:02 PM
Infamous M105/M205 combo; why do I need M105? flaco Ask the Expert featuring Mike Phillips 27 08-17-2010 01:44 PM
Defelsko PosiTest DFT Combo Electronic Paint Thickness Gauge Meghan New Car Care Products 8 10-06-2009 11:24 AM
Best product combo to use with a PC Z06-Goose Auto Detailing University 6 11-02-2006 05:59 PM
» May 2013
» Car Care Brands
