» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 09-30-2012, 01:23 AM   #11
Re: how many of you are no longer using clay?
Like Master detailer said, if its your car then do what you like. If you're charging someone, i'd be a little hesitant. Yes clay can mar, but when a contaminate is picked up with clay it gets embedded in and if it scratches it will be minor. With the nano skin or whatever, the particle has nowhere to go but get dragged around until you notice and watch it. I think clay is safer, and if done right a mild clay wont scratch or mar and wont need polishing afterwards. I'd only nano skin if i was gonna polish 100%.
jrs1418 is offline
Old 09-30-2012, 02:31 AM   #12
Quote:
that's why you would wipe the pad clean with a mf towel after each section, kinda like when it would be time to re-knead the clay...
VISITOR is offline
Old 09-30-2012, 03:28 AM   #13
Quote:
Originally Posted by Jennytay View Post
I think I'll just stick with clay. I like the concept better and I'm not lazy when I detail. Just time I'm getting to spend with my car so the time it takes to clay doesn't bother me. If I can do things by hand with great results then that's what I want to do.
I also prefer the clay concept. I believe it would mar less. However, there is a version of the special contaminant removal cloths that are used by hand. Claying iseasily done by hand. If the cloths truly are faster and easier, why is a DA even needed with the special cloth?
Blackthorn One is offline
Old 09-30-2012, 03:43 AM   #14
Quote:
I understand, but once again.. when clay picks something up it gets embedded into the clay. With the towel the contaminate has nowhere to go except rolled on the paint. You can wipe your towel off every section and this would still apply. Of course with clay the same particle can scratch, but the profile hitting the paint would be minimized and so would the scratch.
jrs1418 is offline
Old 09-30-2012, 05:45 AM   #15
The contaminant can be pulled into the weave of the cloth, away from the paint to a large degree, as well. Once the nap fills up enough with particles, then they will start to scratch significantly. The cloth is not COMPLETELY flat. However, I still think that the clay with lube method is safer. I have not used the cloth, but I know that cloth has fibers, which can collect dirt.
Old 09-30-2012, 07:45 AM   #16
Just because of the way clay works, the abrasive edges at the flattened surface of the clay are pressed into the clay and do not abrade the paint surface. An above-surface contaminant presses into the clay and exposes abrasive from the edges of the divot it creates by pressing into the clay. This is all explained in the patent.
The fact that the clay is deformable makes it different (i.e. selective abrasion of contaminants not the paint surface if used correctly), even if the end result of contaminant removal is the same for both.
In contrast, these pads/towels seem to operate more like a sandpaper sheet, with fixed non-deformable abrasive and substrate which abrades everything--the paint and the contaminant. That's why, in the video, the guy says it also removes paint oxidation. Sometimes you may want that, sometimes not.
The second video above also points out the contaminant particles floating freely on the surface after they are abraded. If the contaminant is itself abrasive, that could be a bummer.
So it really depends what you want to do. I don't see them as 100% interchangeable for everyone, especially if speed is not a priority. If using the DA version I'd probably still want a clay bar around for spots the DA pad cannot reach.
SR99 is online now
Old 09-30-2012, 07:59 AM   #17
Last weekend we had our detail fest and I got to try the Speedy Prep towel on Ivan's sister's Honda Civic and let me tell you guys this, it made a believer out of me, period! Its soooo much faster and easier and I for one don't need to wear gloves anymore when de-contaminating the paint surface anymore, no more sticky clay
Once my clay is used up, I'll be getting a Speedy Prep towel for sure!
__________________
2011 Honda CR-Z EX/6MT/Storm Silver Metallic
"Some say...he likes Swedish fish because they're made with caranuba wax"
Current surface protection count...(83-37)
Klasse Act is offline
Old 09-30-2012, 08:14 AM   #18
Setec Astronomy's Avatar
Quote:
Originally Posted by oldmodman View Post
When my stockpile of clay runs out I will probably try one of the other products. But that will be ten years from now.
Ditto. That's why I never tried the Elastrofoam block/Magna Sponge.
A lot of you here that are knocking the towel don't really seem to understand the product, you've got some pretty way-out descriptions of it that are just wrong (sorry). As far as the economy, if the towel costs $60, that's 3 or 4 blocks of clay, I'm pretty sure the towel is going to last that long or longer, so I'd say the cost is a wash or better, as long as you can afford the up-front money for the towel.
This is going to be a lot more interesting discussion in a year when the clay patents have run out, I'm guessing clay prices are going to drop to half of what they are now, and that will probably drag down the towel pricing too.
PS I'd also expect there to be some clay shortages shortly before the patent expiration, I don't think anyone wants to be stuck with a lot of clay inventory that will all of a sudden be worth half what it was the day before. It's a little murky when the patent expiry is because there are multiple patents, the first of which I believe expires in December of this year.
__________________
"Spray it like you mean it!"
Setec Astronomy is offline
Old 09-30-2012, 08:34 AM   #19
No more clay?!?!?!?
What am I suppose to do with these 14 tubs of Meg's I got on clearence from Advance
Flash Gordon is offline
Old 09-30-2012, 09:14 AM   #20
Quote:
Originally Posted by Flash Gordon View Post
No more clay?!?!?!?
Ebay
Depending on how many detail jobs I get next spring/summer, I may end up with the Speedy Prep towel sooner, its that efficient
__________________
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
How often do I need to clay my car? Mike.Phillips@Autogeek Hot topics and Frequently asked questions 12 07-11-2012 03:24 PM
Weird Clay Bar Experience The Critic Auto Detailing 101 9 11-28-2010 05:45 AM
Tips and techniques for using detailing clay Mike.Phillips@Autogeek How to Articles 7 07-27-2010 07:32 PM
Clay Bar Aggressiveness Scale Mister B Ask the Expert featuring Mike Phillips 4 10-27-2009 10:15 AM
yellow clay for the great white north.. CalgaryDetail International Vendors 69 01-12-2009 05:49 PM
» May 2013
» Car Care Brands
