Lots of wisdom in your statement
mvanbvoo.
OP, if you don't want to be offended...disregard this post.
Pro-detailers that hang their shingle should know not to continue if a panel or part of a panel is not correct.
*Kind of like not doing a test spot and wondering why the process failed.
*Or wetsanding the entire vehicle before knowing whether products at hand could remove wet sanding marks.
* Or using glass cutting pads and a da while trying to remove pitting from a windshield.
Too many detailers making the same mistakes, time and again.
One thing that AGO has is info.
As I type this there are approximately 53,708 threads.
731,026 posts between the forums.
In less than 60 words (didn't really count them all), the OP show his hand.
Ever hear of a "tell" in poker? Well your thread starter speaks volumes.
Everything I thought I knew but didnot...was revealed in this thread.
Strange OptiCoat happening
I'm off my rant now...
