I bought a tube of
Optimum Opti-Coat 2.0 last year and just used it over the summer. I read its directions and watched a couple of videos to see if there was some tip or tick others offer but there really wasn't any, it's pretty straight forward.
What I can tell you is
Optimum Opti-Coat 2.0 doesn't fill so surface preparation is a must, otherwise you'll end up with some nicely protected swirls...
Clean the finish
Be sure you clean the surface thoroughly. This is probably the biggest cause for failed applications.
The instructions say to use an Isopropyl Alcohol mix spray to prepare the way for it's application. Personally, I clean the polished finish with mineral spirits then wipe with clean microfiber towels. Once through, I go over it with the Isopropyl Alcohol mix as a last step before applying the
Optimum Opti-Coat 2.0 product.
Instructions Optimum Opti-Coat 2.0 Permanent Paint Coating FREE BONUS Great Video
Nick did a nice writeup not too long ago that may help as well.
Optimum Opti-Coat 2.0 - Permanent Paint Protection Made Easy Optimum Opti-Coat 2.0 lays down thin, I mean really thin.
Optimum Opti-Coat 2.0 should evaporate almost immediately.If you see depth to it like applying
Ultima Paint Guard Plus it's way too think.I've done 2 cars and a full set of wheels with one tube and I still have some left.
