» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 09-05-2012, 01:09 PM   #1
Member
Meguiars Ultmate Liquid Wax streaking
Anybody else have this problem?
I called Meguiars & they said to WoWo this product but it still streaks
They said because I used #7 to prep with, there is a lot of oils in #7 & quite a bit in UW, that I may have this problem. Boy no kidding!
I applied by hand with the included foam applicator.(my GG 6 DA won't be here for a couple days) I put it on ultra thin & the top layer wipes off easily. But areas where my fingers put a little more pressure on the pad leaves more oils on the paint & thus the streaks of oil.
I can wipe the oil out eventually, but I'm talking some serious wiping, like 2-3 minutes going north to south & then east to west on an 18" X 18" area.
Any suggestions on a faster or better method?
dsigmon is offline
Old 09-05-2012, 01:17 PM   #2
Hunter09's Avatar
Try a 50/50 whip down ?
Hunter09 is online now
Old 09-05-2012, 02:08 PM   #3
Re: Meguiars Ultmate Liquid Wax streaking
I had ULW streak like no body's business the first time I used it -- I applied by hand after using UP.
However, using the PC and doing an IPA wipedown after UP, I noticed zero streaking
eatnosenuggets is offline
Old 09-05-2012, 02:11 PM   #4
Member
What's a 50/50 wipe down?
Will the IPA damage the finish?
dsigmon is offline
Old 09-05-2012, 04:04 PM   #5
Hunter09's Avatar
It's IPA and it won't hurt the paint
Old 09-05-2012, 11:37 PM   #6
Member
So I should wipe down after the polish & before the sealant?
Will the 50/50 IPA solution dull the polish job?
dsigmon is offline
Old 09-06-2012, 09:57 AM   #7
Shakabruddah808's Avatar
I had the same problem when I used ULW as well. Meg's customer service says to use the 'spit shine' method of finely misting surface with ice cold water and then buffing dry, which worked out fine. But to me it was an extra step, so I ditched the ULW and am now using BFWD applied with LC CCS Euro Foam Red Hand Pads. Much thicker and more durable than those flimsy yellow, saucer-shaped ones. Plus the red pads can be washed and re-used repeatedly.
If you don't mind the extra step of 'spit shining', then go ahead and use that method. Or the next time you apply ULW, let dry about an hour and wipe-off. Follow-up immediately with a second application to both ensure even coverage, and to help remove hazing and streaking left from first application.
I really endorse the LC hand pads. There's just something relaxing and therapeutic about hand waxing versus machine application. Some forum members will even call it fun, which it is. I still keep some of those yellow pads around though. Great for getting into those tight spots.
Hope this helps.
__________________
It never fails. Whenever anything hits the windshield, it's always on the driver's side....and at eye level!
Shakabruddah808 is offline
Old 09-06-2012, 01:17 PM   #8
How much are you using? You say thin, but that's no real indicator. Should be able to do a whole car using 1/2oz. The travel sized bottles work great for wax dispensing, they are 3.5 oz, divide in 6 sections, use one of those for the whole car.
yakky is offline
Old 09-06-2012, 01:39 PM   #9
Hunter09's Avatar
After your done waxing if there's streaks u can do a ipa whipe down
Old 09-06-2012, 02:09 PM   #10
pcw25's Avatar
I've had this exact problem a lot with Ultimate Wax, especially on reds and blacks. I just tossed it because it required too much work for a finish that wouldn't last. I would suggest switching over to Collinite 845 or Duragloss 105. Both last longer, and are cheaper.
__________________
Tommy
pcw25 is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Wolfgang Füzion Estate Wax Review Marc08EX Product Reviews 29 11-27-2012 04:48 PM
Sacrificial Barrier Coating = The purpose of a wax or synthetic paint sealant Mike.Phillips@Autogeek Hot topics and Frequently asked questions 10 03-20-2012 08:20 AM
Are Waxes & Sealants Even Necessary?? mattkrmp80 Auto Detailing 101 39 03-22-2011 12:04 PM
Wax removal/buffing with PC7424 vegasdenali Auto Detailing 101 13 02-12-2010 08:28 AM
Product Abbreviation Chart or acronyms! sparkie Hot topics and Frequently asked questions 52 01-14-2010 07:55 PM
» June 2013
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
» Car Care Brands
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
