» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 08-22-2012, 03:48 PM   #21
Director of Training
Mike.Phillips@Autogeek's Avatar
Re: Question after first time using Griots polisher.
Quote:
Originally Posted by civdiv99 View Post
The reply was suggesting never go above speed 4, and don't put any more pressure than the machine's weight itself is.
When I went to work for Meguiar's the second time, (2002), their instructions at that time for using the G100 was to only use the weight of the machine. I think this is also in their Power Polishing VHS Video Tape if anyone still has one around.
I started teaching the Saturday Classes and first thing I did was start showing people to apply around 15 pounds of total downward pressure.
The tool weighs about 5 pounds so that means you have to push down with about 10 pounds and if you get a bathroom scale out and push on it with your hand you'll find out that 10 pounds is NOT that much.
A few years, actually 9 months after starting the MOL forum in 2004 I wrote an article on how to use the G100 for MOL on how to remove swirls and actually use a bathroom scale. To my knowledge this is also the first how-to article ever written on a discussion forum on actually how to use a DA Polisher.
Using the G-100 to remove swirls with the Professional Line
Excerpt
Quote:
15 pounds of pressure on the head of the polisher
20 pounds of pressure on the head of the polisher
Here's another quote from the above article and yes, that is my hand and my bathroom scale and my garage floor in Apple Valley, California.
Note about the pressure applied to the head of the polisher...
I've placed my hand on a scale before and often times guesstimated how hard to push down on the buffer head, but today I covered our bathroom scale with a thick plastic from a bag I cut up, taped it securely around the scale, then experimented running the polisher over the scale using the correct pad and chemical to try as best as I could to duplicate the exact thing I would do if I we're working on a real car.
I've polished out hundreds of cars using both the rotary buffer and the dual action polisher and have a pretty good feel for how much pressure to apply depending on what you want to accomplish.
To tell you the truth, I was quite surprised by the scale readings myself. I posted a range because that's truly how the dual action polisher works, it works within a range of pressure not a set number. Another factor is the condition of the paint, paint with only light swirls will only need pressure in the 15 pound range while paint with really deep swirls and harder paint will require pressure in the upper range running anywhere from 17 to 20, maybe even bumping over 20.
It was not a perfect system, but I'm confident the numbers are in the real world correct range. If you have a scale, and you have experience polishing out swirls with a dual action polisher using a foam pad like our W-8006 foam polishing pad, give it a try and compare notes.
Also when applying a wax, I found a little more than the weight of the polisher, yet enough to keep the pad flat against the finish was around the 10 pound range. For more cleaning ability, a person could apply a tad more pressure, so the range depends upon what you're trying to do.
These are all just suggestions, or course you can experiment with your car's finish and determine what works best for you.
Remember, it's not just about breaking down abrasives; it's about removing below surface defects. You remove below surface defects by removing the upper level paint that surrounds them.
Gliding the dual action polisher over a clear coat finish will not remove paint.
Pushing down on the polisher, moving it slowly and the combination of time, your pad choice, chemical and oscillating action, gently and carefully abrade and remove small amounts of paint which levels the finish and thus removes the defects.
Two points...
1. Manufactures will often times put out a safe approach to protect people from themselves. "We" all know that we all push technology to its limit so figuring out it takes more than the weight of the machine gliding over the paint to remove swirls and scratches is what's really necessary.
2. The way you remove paint is you engage the abrasives with the paint so they take little bites out of the paint. You engage the abrasives into the paint by pushing them into the paint and this is done with downward pressure no matter what the tool including your hand.
3. The best how-to information comes from someone that actually has been there and done that...
I guess that's three points...
__________________
How-To Articles
Live Broadcast Videos & Pictures
Facebook
Mike.Phillips@Autogeek is online now
Old 08-22-2012, 04:59 PM   #22
Kevin Cullen's Avatar
Thanks for the reply Mike.
Kevin Cullen is online now
Old 08-22-2012, 05:17 PM   #23
Rsurfer's Avatar
[QUOTE=Mike.Phillips@Autogeek;726861]
LC Hydro-Tech pads are close-celled so they hold liquids in and thus hold heat in...
I thought close celled foam (H2O) prevented liquids from absorbing into the foam. Isn't it why they recommend Hydro Tech pads for water based polishes? Please correct me if I'm wrong Mike.
Rsurfer is offline
Old 08-22-2012, 07:00 PM   #24
richy's Avatar
So I see you were married before.
__________________
My Website: http://www.flawlessreflectionsautodetailing.com
richy is offline
Old 08-22-2012, 07:31 PM   #25
this is why you use a bunch of pads to do a car. dont over saturate or overheat them or this will happen everytime.
Also the GG polisher is notorious for transferring heat to pads faster than other DA polishers, so you have to be twice as careful not to overheat or oversaturate the pads.
since this is you first time using the polisher you probably loaded up with product on the pad and helped the issue along.
mg6045 is offline
Old 08-22-2012, 09:11 PM   #26
Member
LF911PCR's Avatar
Maybe I should have done better due diligence on the Griots. The one thing that REALLY surprised me about the Griots...the vibration. Wow! Wasn't expecting it...
Do all DAs vibrate like that?
LF911PCR is offline
Old 08-22-2012, 09:11 PM   #27
swanicyouth's Avatar
On a side note, they are now selling pads in England with THE WHOLE CENTER CUT OUT. kind of like a doughnut. The idea is, if the center is missing, head and product cant build up there.
swanicyouth is offline
Old 08-22-2012, 10:01 PM   #28
Rsurfer's Avatar
They have them in the US..it's called DF Pads or something like that.
Quote:
Rsurfer is offline
Old 08-22-2012, 11:50 PM   #29
c5errr's Avatar
ive been using LC CCS pads for a long time and never had any problems with them
but i heard alot of complaints about those hyper tech pads i never tried them
always CCS
c5errr is offline
Old 08-23-2012, 04:49 PM   #30
blue986s's Avatar
I alway love Mike's detailed, thoughtful, scientific approach to problem solving! Thanks, Mike!
blue986s is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
DA Polisher Articles - Help for Newbies to Machine Polishing Mike.Phillips@Autogeek Questions about the Porter Cable 7424XP, 7424, 7336, Griot's and Meguiar's Dual Action Polishers 15 01-22-2013 07:47 PM
few qeustions about m105 and wax sumair Auto Detailing 101 7 07-19-2012 06:23 AM
How to prime a foam pad when using a DA Polisher Mike.Phillips@Autogeek How to Articles 27 04-24-2012 06:08 PM
3" Mini Polisher- Gen II - Griot's Garage Mini Polisher Mike.Phillips@Autogeek Product Reviews 25 08-22-2010 03:30 AM
Time to update! k_christman Ask the Expert featuring Mike Phillips 8 05-11-2010 08:43 AM
» May 2013
» Car Care Brands
