» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 08-04-2012, 05:58 PM   #1
Member
Snowdrifter's Avatar
Acceptable way to measure if I've used enough soap?
I've always filled my bucket with water and squirt it some soap, mix it up, then reach in and rub my fingers together. If they feel slippery, then I'm good. If not, they I add more soap and repeat.
Is this a fine way to do it or not? I reason that if my fingers slide by each other, than the dirt too will slide off my paint.
And as a side note: what's a nice smelling, slick soap that is cheap per wash? I've always used meguiars GC, and have moved to ultimate. But im wondering if there is anything else that might be more effective since I can't buy the ultimate wash in bulk?
Snowdrifter is offline
Old 08-04-2012, 06:04 PM   #2
Re: Acceptable way to measure if I've used enough soap?
Use a measuring cup for the best accuracy. I bought a small one from walmart that is made of glass and has just about everything you can imagine on it as far as measuring liquids. Then go by the soaps directions for how much to use per gallon of water.
KillaCam is offline
Old 08-04-2012, 06:06 PM   #3
Hammondc's Avatar
One of the proportioners that AG sells. Fits on top of the soap bottle. Like $6.
Hammondc is offline
Old 08-04-2012, 06:11 PM   #4
I use one of those 3oz looped measuring cups from AG and follow directions. Using too little soap is one problem but using too much will strip the wax faster, and I don't like waxing the cars more often than I have to.
I add soap first, just over 3oz's, then add three gallons of water with the nozzle underwater to avoid foaming. Then I pull it out and blast in a little more for foam.
I really like Megs shampoo plus. It leaves the car feeling waxed better than a lot of soaps that supposedly have wax in them. Plus it doesn't strip the wax too fast.
Silverstone is offline
Old 08-04-2012, 06:13 PM   #5
Member
But do I need one - like is having a very precise soap/water ratio that important? Is there something wrong with my methods? If I get a portioner, wouldn't I then have to measure the water too?
Hmm... And entire post made of questions lol
Old 08-04-2012, 06:30 PM   #6
I don't like the proportioners. I bought one and don't even use it anymore. It's nearly impossible to rinse the thing out completely and if you leave soap, apc, or whatever it is in there and it dries, you're screwed. They are also very expensive.
KillaCam is offline
Old 08-04-2012, 06:38 PM   #7
ziggo99's Avatar
1. Yes. A precise ration gives you the right amount of cleaning power without stripping the protection as quickly.
2. Unless you got a Masters in eyeballing, then your method isn't giving you a proper
3. Take a gallon milk jug and a black or silver Sharpie (depending on bucket color) and make a mark at each gallon mark. So if your wash calls for 1gal:1oz, you fill the bucket to the right mark, then add the correct amount of soap.
__________________
Kyle
Quote:
Originally Posted by Dugdug View Post
Anyways, a customer with a hummer asked me if there was a surcharge for his hummer. I said yes, it's an SUV. He said quote "well it's an H3, so it's not really an suv".......
ziggo99 is offline
Old 08-04-2012, 08:37 PM   #8
david79z28's Avatar
I use a paint mixing cup. It hash marks for ounces as well as marks for certain reduction rates when mixing quarts. I use those when making ONR detailer, waterless wash, etc.
david79z28 is offline
Old 08-04-2012, 08:45 PM   #9
The way you're doing it is fine. You don't need no stinking measuring cup for soap
I try to stay away from scented products, so I have no recommendations for you on a pretty smelling soap
Flash Gordon is offline
Old 08-04-2012, 08:45 PM   #10
D.Acker's Avatar
I use Griot's soap in a Griot's bucket. The soap specifies 1 ounce per 2 gallons of water. The bucket has a 3 ounce cup built into the grit guard and is a 6 gallon bucket, can't get much easier.
I use both Meg's GC and Griot's, both smell nice and both do a nice job of waxing and neither seems to strip wax to fast for my liking.
__________________
Dave
'00 Tropic Green SVT Contour \ #905 of 2150,
'06 Grand Caravan SXT
D.Acker is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Interesting thought .... Car Wash Soap killrwheels@autogeek Auto Detailing 101 31 01-15-2011 12:58 PM
DP Car Soap the_invisible DP 3 08-26-2010 03:51 AM
Measuring the correct amount of soap CieraSL Tricks, Tips and Techniques 21 04-18-2010 11:32 AM
Optimum Soap review (found the soap I have been looking for) wytstang Auto Detailing 101 26 10-29-2007 11:43 PM
New foam gun soap dakevmann New Car Care Products 23 06-27-2006 10:45 AM
» May 2013
» Car Care Brands
