» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 08-04-2012, 09:12 PM   #11
Jaretr1's Avatar
Re: Acceptable way to measure if I've used enough soap?
I have been pretty pleased with DP Auto Bath. Its super concentrated and suds up really nicely. I believe AG sells it in bulk.
I just squirt some into a bucket by eyeball method. If I get decent suds, then I know I have enough. If I get super thick lather, then I know I have used to much.
Megs probably sells something equivalent to GC in the professional line, I did not look, but glance through it, I am sure they have a car wash among their professional products that can be purchased in bulk.
Jaretr1 is offline
Old 08-05-2012, 05:14 AM   #12
Bunky's Avatar
I use those plastic disposable 1 ounce cups to measure.
However, this may be overly precise when some soap direction says 1 to 2 capfuls in a bucket of water. However, some soaps like Do Do Juice are very concentrated.
For those relying on between the finger slickness, ONR never feels slippery like soap does. Adding extra soap should translate to better cleaning capability more "safety".
__________________
Al
The Need to Bead
Bunky is offline
Old 08-05-2012, 06:17 AM   #13
BobbyG's Avatar
I have a couple of plastic scoops left over from protein powder. They're convenient and easy to use and repeatable.....
__________________
BobbyG is offline
Old 08-05-2012, 07:39 AM   #14
You can also get (and use) pump dispensers that just screw on your soap jug. They come on various amounts (ie, one ounce, two ounce, etc.). Check out your local janitorial supply store.
Bill
BillE is offline
Old 08-05-2012, 11:40 AM   #15
Quote:
I thought of doing that also. I guess I will measure to see how many ounces they hold and start using them!
KillaCam is online now
Old 08-05-2012, 11:44 AM   #16
Member
Chemical guys citrus wash and gloss! 1 capfull for 4-5 gallons gallons of water
Kemer1 is offline
Old 08-05-2012, 12:28 PM   #17
Infinitiman's Avatar
I would recommend that you use measuring cups, AGO sells some for around a dollar for a three pack. Then I would use the manufactures recommendation as to how much product to use. I.E. chemical guys citrus wash and clear calls for .5 of an ounce per 2 gallons for a maintenance wash, but if you are wanting to strip old wax you will use 2 oz per gallon of water. The point being is that some, but not all,car shampoos will effect the longevity of your car wax if you use to much.
Sent from my iPad using Tapatalk HD
Infinitiman is offline
Old 08-05-2012, 01:29 PM   #18
Member
ssnobrakes's Avatar
Cool Re: Acceptable way to measure if I've used enough soap?
Sounds like a good way to waste soap. You may be putting in more than you need...... I use the plastic 1 oz cup that comes from a bottle of NYQUIL for colds/flu. For a good soap priced well try Mothers California Gold with Carnuba at Walmart. Great suds, great smell, great lubricity and you can get it for 5 bucs when its on sale.
ssnobrakes is offline
Old 08-05-2012, 04:58 PM   #19
Member
Snowdrifter's Avatar
Thanks guys! I etched in some lines on my bucket and a plastic cup so I can get an accuring 5oz/5 gallons
In terms of how it feels: slick, just as if I did it by hand. But I am using around 3/4 the soap I was using to get the same feel.
I never knew that using too much will strip the wax... That's interesting.
Snowdrifter is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Interesting thought .... Car Wash Soap killrwheels@autogeek Auto Detailing 101 31 01-15-2011 12:58 PM
DP Car Soap the_invisible DP 3 08-26-2010 03:51 AM
Measuring the correct amount of soap CieraSL Tricks, Tips and Techniques 21 04-18-2010 11:32 AM
Optimum Soap review (found the soap I have been looking for) wytstang Auto Detailing 101 26 10-29-2007 11:43 PM
New foam gun soap dakevmann New Car Care Products 23 06-27-2006 10:45 AM
» May 2013
» Car Care Brands
