» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 07-30-2012, 11:04 PM   #11
Buckskincolt's Avatar
Re: Cannot remove swirls
Quote:
Originally Posted by Vegas Transplant View Post
Combination of errors, too...probably. Such as over saturation of product.
Yes I agree! If you use too much product the WG TSR is like polishing with butter.
__________________
"Labor is prior to, and independent of, capital. Capital is only the fruit of labor, and could never have existed if labor had not first existed. Labor is the superior of capital, and deserves much the higher consideration." Lincoln's First Annual Message to Congress, December 3, 1861.
Newport, Oregon USA!
Buckskincolt is offline
Old 07-30-2012, 11:22 PM   #12
Vegas Transplant's Avatar
OAN, did your shipment ever arrive?
EDIT: Survive the train wreck?
__________________
VT
Vegas Transplant is offline
Old 07-31-2012, 02:38 AM   #13
umi000's Avatar
Quote:
Originally Posted by TP143 View Post
Hi all,
I have given this a few attempts now without success. I am using a GG6/WG Total Swirl Remover/Orange Pad combo on a 06 black Ford Fusion. I have watched all the videos and believe I am replicating the process. I have given 6-8 passes on speed 5&6 on a few areas of the vehicle and only 50% or so of the swirls are removed. Even at slower pass speeds I do not achieve better results. Besides a ton of swirls my paint is fine. Do you think I need to step up to a more heavy duty compound/pad or is this only for imperfections greater than swirls? Any other thoughts?
Thanks
Which orange pad, LC or Griot's? I might be remembering things wrong, but I think I read that the Griot's orange pad doesn't really have a great amount of cut.
__________________
Francis
umi000 is offline
Old 07-31-2012, 02:56 AM   #14
magna_power's Avatar
I always worry about the amount to downward pressure with an orange CCS pad, I'm afraid I'm going to dent a panel pushing down when there is such little give in the orange pad :S
magna_power is offline
Old 07-31-2012, 06:59 AM   #15
Director of Training
Mike.Phillips@Autogeek's Avatar
First read this, everyone should read this BEFORE running into problems as it's a check list to avoid the common problems. Someone once suggested it to be included with ever order and it can be, simply add my how-to book to the order as it's in my how-to book on page 95
DA Polisher Trouble Shooting Guide
Tyler, age 15 removing swirls using a Porter Cable 7424XP Dual Action Polisher
When you're first starting out machine polishing and learning to use a DA Polisher it's common to have questions about your results and your results are directly tied to your technique.
Here's a list of the most common problems,
1. Trying to work too large of an area at one time.
2. Moving the polisher too fast over the surface.
3. Using too low of speed setting for removing swirls.
4. Using too little downward pressure on the head of the polisher.
5. Using too much downward pressure on the head of the polisher so the pad quits rotating.
6. Not holding the polisher in a way to keep the pad flat while working your compound or polish.
7. Using too much product or using too little product.
8. Not cleaning the pad often enough.
Here's a list of the solutions in matching order,
Shrink the size of your work area down. You can't tackle to large of an area at one time. The average size work area should be around 20" by 20". Most generic recommendations say to work an area 2' by 2' but for the correction step, that's too large. You have to do some experimenting, (called a Test Spot), to find out how easy or how hard the defects are coming out of your car's paint system and then adjust your work area to the results of your Test Spot. The harder the paint the smaller the area you want to work.
For removing defects out of the paint you want to use what we call a Slow Arm Speed. It's easy and actually natural for most people new to machine polishing to move the polisher quickly over the paint but that's the wrong technique. One reason I think people move the polisher too quickly over the paint is because they hear the sound of the motor spinning fast and this has psychological effect which causes them to match their arm movement to the perceived fast speed of the polisher's motor.
Another reason people move the polisher too quickly over the paint is because they think like this,
"If I move the polisher quickly, I'll get done faster"
But it doesn't work that way. Anytime you're trying to remove swirls, scratches, water spots or oxidation using a DA Polisher you need to move the polisher s-l-o-w-l-y over the paint.
When first starting out many people are scared of burning or swirling their paint, so they take the safe route of running the polisher at too low of a speed setting but this won't work. The action of the polisher is already g-e-n-t-l-e, you need the speed and specifically the pad oscillating and rotating over the paint as well as the combination of time, (slow arm speed), together with the abrasives, the pad aggressiveness, and the downward pressure to remove small particles of paint which is how your remove below surface defects like swirls or scratches.
Removing below surface defects is a leveling process where you need the abrasives to take little bites out of the paint and to get the abrasives to take these little bites with a tool that uses a Free Floating Spindle Bearing Assembly you need all of the above factors working for you including a high speed setting.
For the same reason as stated in #3, people are scared, or perhaps a better word is apprehensive, to apply too much downward pressure to the polisher and the result of too little pressure is no paint is removed thus no swirls are removed.
If you push too hard you will slow down the rotating movement of the pad and the abrasives won't be effectively worked against the paint. You need to apply firm pressure to engage the abrasives against the paint but no so much that the pad is barely rotating. This is where it's a good idea to use a permanent black marker to make a mark on the back of your backing plate so your eyes can easily see if the pad is rotating or not and this will help you to adjust your downward pressure accordingly.
Correct technique means finding a balance of applying enough downward pressure to remove defects but not too much downward pressure as to stop the rotating movement of the pad.
This balance is affected by a lot of factors like the lubricity of the product you're using, some compounds and polishes provide more lubrication than others and this makes it easier to maintain pad rotation under pressure.
Another factor that can affect pad rotation are raised body lines, edges and curved surfaces as anytime you have uneven pressure on just a portion of the face of the pad it can slow or stop pad rotation. This is where experience comes into play and experience comes from time spent behind the polisher.
Applying pressure in such a way as to put too much pressure to one edge of the pad will cause it to stop rotating and thus decrease abrading ability.
Too much product hyper-lubricates the surface and the result is that abrasives won't effectively bite into the paint but instead will tend to skim over the surface. Overusing product will also accelerate pad saturation as well increase the potential for slinging splatter onto adjacent panels.
Too little product will means too little lubrication and this can interfere with pad rotation.
Again there needs to be a balance between too much product and too little product and finding this balance comes from reading articles like this one, watching videos an most important, going out into the garage and putting in time behind the polisher and as you're buffing with specific product and pad combinations, pay attention to pad rotation.
Most people simply don't clean their pad often enough to maximize the effectiveness of their DA Polisher. Anytime you're abrading the paint you have two things building up on the face of your buffing pad,
  • Removed paint
  • Spent product
As these to things build up on the face of the pad they become gummy and this has a negative affect on pad rotating plus makes wiping the leftover residue on the paint more difficult. To maintain good pad rotation you want to clean your pad often and always wipe-off any leftover product residue off the paint after working a section. Never add fresh product to your pad and work a section that still has leftover product residue on it.
Pad Cleaning Articles
Why it's important to clean your pads often...
How to clean your foam pad on the fly
How to use the Grit Guard Universal Pad Washer
Tyler, age 15 machine applying a paste wax using a Porter Cable 7424XP Dual Action Polisher
__________________
How-To Articles
Live Broadcast Videos & Pictures
Facebook
Mike.Phillips@Autogeek is online now
Old 07-31-2012, 06:59 AM   #16
Video: Mark your backing plate to make it easy to see pad rotation
Here's a quick video that show how and why to mark your backing plate to see and monitor pad rotation while doing any correction or polishing steps.
It's also important to maintain pad rotation with PC style tools when using a one-step cleaner/wax or AIO type product on neglected paint.
It's not vital to maintain pad rotating when applying a finishing wax or finishing paint sealant to a finish that you've just buffed out.
Note: Finishing Waxes and Finishing Paint Sealants would be of the type that don't offer any cleaning or abrading ability.
See my article here,
The Difference Between a Cleaner/Wax and a Finishing Wax
Subtitle: How To Choose The Right Wax or Paint Sealant for your Detailing Project
Also see these videos...
Video: How to remove shallow RIDS and how to machine apply both a paint sealant and a finishing wax
Video: How to buff tight areas plus concave and convex curved panels by machine
Video: Tips for using a Rotary Buffer and the Flex 3401 on vertical panels
__________________
How-To Articles
Facebook
Old 07-31-2012, 07:04 AM   #17
And of course, BEFORE buffing out an ENTIRE car, first dial in your process and make sure you're getting GREAT results to one small area before buffing out the entire car.
If you can't make one area look GREAT then you're not going to be able to make the ENTIRE car look good.
Make sense?
Your test spot tests 4 things,
  • Product choice
  • Pad choice
  • Tool Choice
  • Your skill and ability
How To Do a Test Spot
A Test Spot
A Test Spot is where you take the products, pads, tools and your best technique and buff one small section, usually on a horizontal panel, to test out these things to see if they'll create the results you want, hope for and dream about in some cases.
If your choice of products, pads, tools and technique works to remove the defects and restore the finish to your expectations, then theoretically you should be able to duplicate the same process to the rest of the vehicle and create the same results.
If your choice of products, pads, tools and your technique doesn't create the results you want, hope for and dream about then you can come to the forum and post what you're seeing and we'll do our best to help you tweak your technique, substitute different products, pads and/or tools to see you through to success.
Tape Line
It helps to place a piece of painter's tape on a horizontal surface, usually the hood or trunk lid but if you want to be more discreet you can use the roof. Then only work on one side of the tape line as this will make it very easy for you to see visual changes due to the distinct demarcation line between before and after results.
Tape-line using 3M Green Painter's Tape
Before and after results along the demarcation line
Test Spot performed by Nick Rutter @ Autogeek on a severely oxidized 2006 GMC Canyon
Here's a series of pictures taken by my co-worker Nick from a severely neglected truck he helped another co-worker Jason to buff out. For this project Nicked performed a Test Spot and the pictures really tell the story of what a Test Spot would look like that I've created this article using these pictures and Nick's permission.
The project vehicle is a severely neglected 2006 GMC Canyon with a heavily oxidized clear coat finish. In this case Nick used a one-step cleaner/wax applied by machine but you would buff the paint in the same way with whatever "system" you were planning on using.
If using a multiple step approach then you would use all the products and do all the steps to your Test Spot because this would be what you would do to the entire vehicle if the results from your Test Spot are good and you want to see what the true end-results are going to be. You can if you want skip applying the LSP or Last Step Product if you're happy with the last prep step as in most cases the application of your LSP will simply either make the paint look even better or maintain the results you've created.
Test Spot
Hood Competed
Truck completed
See the original write-up for this project here,
How To: Maximize Time with a Cleaner Wax/AIO
Test every detailing project that's new to you
If you've never worked on the paint on the project you're currently detailing, the before you buff out the entire car, take a moment to do a Test Spot.
I do a Test Spot on ever car I work on as this give me an idea of,
  • How the paint reacts to machine polishing
  • How the products and pads are working on this specific type of paint
  • A feel for if the paint is hard or soft or somewhere in-between
  • A very good idea as to how the paint will and thus how the vehicle will look after the project is finished.
Plus, if you're buffing out the car professionally you can share with your customer how awesome they're car is going to look after you get through with it.
Here's the results from some of the Test Spots we've done to some of the recent projects cars here at AGO
1959 Chevrolet El Camino - Extreme Makeover - Modeled by Christina
Live Broadcast Video - 1965 Plymouth Valiant - Extreme Makeover
Before
Test Spot
After
Wetsanding Test Spot
Even if you're going to wetsand or dampsand a vehicle it's just as important to do a Test Spot by sanding a section of paint and then testing to see what it's going to take to remove 100% of your sanding marks.
Test Spot
Hood compounded
After
Test, test, test...
Test out the products you're planning on using over the entire vehicle to one small area first. Make sure you're getting the results you want, hope for and dream about before buffing out the entire project.
__________________
How-To Articles
Facebook
Old 08-02-2012, 09:41 PM   #18
fahoumh's Avatar
Mike, if I prime a dry LC foam pad with product like you showed in your "How to prime a foam pad when using a DA Polisher" article then clean the pad "on the fly" with a terry cloth do I need to re-prime the pad before I get back to polishing? I'm sorry if this is a stupid question.
__________________
Hassan
fahoumh is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Tips & Techniques for using a Spray Detailer to Remove Light Dust, Fingerprints and Smudges Mike.Phillips@Autogeek Tricks, Tips and Techniques 25 02-28-2013 09:16 PM
Audi swirl help needed!!! courtsider Auto Detailing 101 19 07-18-2012 11:17 AM
I'm new to using a Makita 9227c Polisher #1STUNNA Auto Detailing 101 13 05-03-2011 01:17 PM
Problem working with Meguiar's M105 Ultra Compound? nabisco shine Hot topics and Frequently asked questions 55 07-06-2010 01:44 PM
Show Car Garage Video: How to use the Cyclo Polisher to remove swirls and scratches Mike.Phillips@Autogeek Show Car Garage How to Videos 2 06-23-2010 06:42 PM
» May 2013
» Car Care Brands
