» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 07-26-2012, 11:07 PM   #1
Member
mammoth713's Avatar
Need advice on CCS Pads..?
I need a reminder on how to use these CCS pads with products..
On a scale from greatest to least cutting is this true:
*Yellow -> M105
*Orange -> M105
*Orange -> M205
*White -> M205
*Green -> M205
*Green -> Poorboys World Polish with Sealant AIO
*Gray -> Poorboys World Polish with Sealant AIO
*Blue -> Poorboys World Polish with Sealant AIO
Also,
Should you only use M105 with Yellow and Orange pads
and M205 with White pads?
I currently have yellow, orange, white, gray, and blue pads. Would the green polishing/finishing pad be worth buying to use with the "poorboys world polish with sealant AIO" or would there not be much of a difference?
Do you ever use the gray, blue, or red finishing pads? What is the difference between them?
In short, I am confused on which pads to use with the following products:
*M105
*M205
*Poorboys world Polish
__________________
mammoth713 is offline
Old 07-26-2012, 11:42 PM   #2
Nicholas@Autowerx's Avatar
Re: Need advice on CCS Pads..?
Quote:
Should you only use M105 with Yellow and Orange pads and M205 with White pads?
It depends on the results you are looking for and the paintwork you are working on. I don't think I could elaborate on this without writing 5 paragraphs. I just started typing out an essay and realized it was hopeless...
I will leave you with these instead. They will be much more helpful!
Autogeek Buffing Pad Comparison Chart
Autogeek Swirl Removers & Compounds Comparison Chart
__________________
Nicholas Scafidi
www.autowerxdetailing.com
Like us on Facebook
Nicholas@Autowerx is online now
Old 07-27-2012, 12:45 AM   #3
Member
mammoth713's Avatar
thank you for the response. I had the link to the compound comparison but I didnt have the buffing pad comparison.
So after reviewing it, would this be a good order of things in worst case to best case? I would start @ START for the car if it was in good condition (few or no swirls). If the paint needed correction, I would start higher up and trickle back down the chart:
Also, is the green pad worth getting? Does it make a big enough difference between the gray vs white pads?
PBW PwS = Poorboys World Polish with Sealant AIO
__________________
Old 07-27-2012, 01:43 AM   #4
Your workflow chart seems perfect in terms of product/pad pairings. The only thing I would say is don't be afraid to bump up your speed when compounding all the way to 6. It's there for a reason.
I've never used the green polishing pads. I thought about getting some but I don't like the idea of being able to accidentally confuse them with the green cutting pads. I always figured if I had enough white pads the green pads would just never get used.
__________________
Nicholas Scafidi
Like us on Facebook
Old 07-27-2012, 03:57 AM   #5
umi000's Avatar
I'd bet that Kevin Brown would tell you to give M105 a try with the lower-cut pads
__________________
Francis
umi000 is offline
Old 07-27-2012, 11:24 PM   #6
Member
mammoth713's Avatar
gotcha
Quote:
Yeah I might try 105 with a white pad and see the results. I havent tried it.
This leads me to a few more questions..
*Can I use a gray or white ccs pad on taillights/headlights with M205 and Plastix?
*Which has more cut: M105 w/ white pad vs M205 w/ orange pad. This is where I get confused.
__________________
Old 07-28-2012, 03:30 AM   #7
Gray CCS won't do much at all on headlights that are severely oxidized. White or orange with m205 would be a better choice.
I would say m105 w/ white pad would have more cut and would absolutely remove defects better than m205 w/ orange. It really all depends on the paint though. This is when a test spot comes in handy. With a DA either combo would be a great 1-step correction process.
Sent from my LG-VM701 using AG Online
__________________
Nicholas Scafidi
Like us on Facebook
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Melted CCS Pads? Thoughts? lokerola Ask the Expert featuring Mike Phillips 2 06-20-2012 09:50 PM
Melted CCS Pads? Thoughts? lokerola Ask the Expert featuring Mike Phillips 24 06-19-2012 06:29 PM
5.5" CCS Pads > 5.5" LC Flat Pads FivePoint.0 Auto Detailing 101 10 04-25-2010 12:28 PM
PC and LC 5.5 CCS Pads belcherm58 Questions about the Porter Cable 7424XP, 7424, 7336, Griot's and Meguiar's Dual Action Polishers 4 09-05-2009 01:45 PM
NEW- CCS Spot Buffs 4 x 1.25 inch Pads Meghan New Car Care Products 22 09-20-2007 04:20 PM
» May 2013
» Car Care Brands
