» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 07-26-2012, 01:08 PM   #11
Buckskincolt's Avatar
Re: My first detailing job.
Quote:
Originally Posted by Johny B View Post
HI Guys,
I have ordered 5.5" pads from AG hoping that my 7424XP PC will work better and the pads won't stop spinning even if no pressure is applied. If the problem persists I'm going to buy the Flex3401 which is more powerful. I will keep the PC to work with smaller pads.In fact can I buy a smaller backing plate let's say 3" to work with same diamter pads or should I but 3.5 BP and use 4" pads for hard to reach area like near windows, the mirror etc....
Johny
You will be much happier with the 5.5" pads but it won't compare to the power of the forced rotation of the flex.
Do you have or did you order the 5" backing plate to go with the 5.5" pads? You will need it if you don't have it.
Yes you can buy a smaller backing plate for use with 3 and 4" pads. I use my GG6 for 5.5" pads and my Pc for 4 and 3" pads.
3 Inch Dual Action Flexible Backing Plate, da backing plate, random orbital backing plate
__________________
"Labor is prior to, and independent of, capital. Capital is only the fruit of labor, and could never have existed if labor had not first existed. Labor is the superior of capital, and deserves much the higher consideration." Lincoln's First Annual Message to Congress, December 3, 1861.
Newport, Oregon USA!
Buckskincolt is offline
Old 07-26-2012, 03:15 PM   #12
Nicholas@Autowerx's Avatar
Nice work.
__________________
Nicholas Scafidi
www.autowerxdetailing.com
Like us on Facebook
Nicholas@Autowerx is offline
Old 07-26-2012, 04:20 PM   #13
Member
Great job. What polish and steps did you end up using.
jminrod is offline
Old 07-26-2012, 11:15 PM   #14
Johny B's Avatar
Hi jminrod,
I have used Meguiar's clay bar first, then Chemical Guys Glossworkz glaze,CG Blacklight Hybrid radiant finish and CG Hybrid V7 gloss spray sealant.
Johny
Johny B is offline
Old 07-27-2012, 05:36 AM   #15
BobbyG's Avatar
Hi Johny,
The SUV did come out looking great!
The Porter Cable 7424xp is a great machine but in my opinion 6 1/2" diameter pads are just too big for it and many of the other machine of this type as well.
Two machines not part of this group are; the Flex 3401 and the Makita's BO6040 which is the new kid on the block.
The Flex and the Makita both have forced rotation which means you no longer need to worry about the balance between friction and downward force to ensure that the pad continues to spin.
This is an article I wrote and posted several times..
Pad Sizes
The 6 1/2" diameter pads a Porter Cable 7424 pushes the limit of the machine and this could be part of the problem.
I have this machine and found a world of difference when I decided to try Lake Country 5 1/2 diameter pads.
The Porter Cable 7424 style dual action polisher should come standard with 5 1/2 inch pads and corresponding backing plate.
Pads & Friction
The size or surface area does not directly affect the frictional force between two surfaces until downward force or pressure is applied. Reducing the pad size will only improve the mechanical efficiency of the machine.
The motor of your polisher produces some amount of power. The larger the pad surface area the harder the motor must work. Now, most will say "it's only 1 extra inch", but when it comes to surface area and friction you’re really talking about an additional 10 square inches. Now take a look at the difference between the 5 1/2", 6 1/2" and 7" pad...........Size does matter!
Surface Area - 5 1/2 pad = 23.75 in˛
Surface Area - 6 1/2 pad = 33.18 in˛
Surface Area - 7 pad = 38.484 in˛
There is a direct relationship between the pad surface area and the polishers ability to transfer adequate power to the pad improving its overall performance.
I have the Porter Cable 7424 first generation which has less power than the current generation. It has little problem handling the smaller size pads and this is what I recommend to anyone who uses this style of machine.
The Flex 3401 is priced at nearly $400 and the Makita BO6040 comes in second place at $300 so neither of these machines are cheap by any means.
I haven't tested the BO6040 but I do have the Flex 3401 and it is the best dual action machine on the market today....my opinion of course...
__________________
BobbyG is offline
Old 07-27-2012, 07:34 AM   #16
vet
vet's Avatar
Good job!
vet is offline
Old 07-27-2012, 12:08 PM   #17
Director of Training
Mike.Phillips@Autogeek's Avatar
A little disappointment with the power of my new 7424XP PC which seems to improve difficulties in spinning 6.5" CCS needless to mention that the microfiber bonnets are useless with this tool due to it's lack of power.'
Got your PM and checking out your thread, for what it's worth, my how-to book recommends 5.5" pads and explains why.
I also have a history of recommending 5.5" "thin" pads for use with all the PC "style" pads because these tools do have a harder time maintaining pad rotation under pressure with,
  • Larger pads
  • Thicker pads
Coined the term, thin is in...
Thin is in... New Lake Country Hydro-Tech Low Profile 5 1/2 x 7/8 Inch Foam Pads
__________________
How-To Articles
Live Broadcast Videos & Pictures
Facebook
Mike.Phillips@Autogeek is offline
Old 07-27-2012, 10:35 PM   #18
Johny B's Avatar
Hello,
Thank you guys for your explanations.I will try the CSS 5.5" pads but as BobbyG said the best polisher is the Flex no doubt about it. It's expensive but I imagine the time saved and for sure you work with a more powerful tool.From now I'm watching discounted price from AG and the Flex 3401 will be in my cart.
Johny.
Johny B is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Mike Phillips' Detailing Boot Camp Mike.Phillips@Autogeek Company & Forum News Headlines 96 04-29-2013 07:14 AM
Articles by Mike Phillips Mike.Phillips@Autogeek Ask the Expert featuring Mike Phillips 57 06-04-2012 10:26 AM
The Art of Detailing by Mike Phillips Nick@Autogeek Company & Forum News Headlines 72 10-25-2011 02:55 PM
Show Car Garage Video: How detailing clay works and how to use detailing clay to remove above surface bonded contaminants Mike.Phillips@Autogeek Show Car Garage How to Videos 16 07-11-2010 02:33 PM
unfinished detailing job.... JCB Auto Detailing 101 15 10-04-2006 01:52 AM
» May 2013
» Car Care Brands
