| Costco Snap On pressure washer foam lance fitting?
Anyone know what's needed to make a foam lance / cannon work with the costco 1750 or the 2000 psi pressure washer? I've read another post where the OP stated the Snap-on fitting is a tad bigger than a standard fitting, and want to confirm this with someone who has this setup. Curious if the two fittings are different as well.
If the threads are unique, it looks like a new gun / hose might be needed.
