» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 06-18-2012, 12:23 PM   #1
Largebore's Avatar
Megs mf system question
How important is the megs backing plate? I just did some work on my car with the system, ie: cutting and finishing pads and chemicals. Typicaly I would have used Menz compound and yellow pad as the area had a bunch of scratches.
Anyway, the megs system was unimpressive at best.
However I did not use their backing plate. Although I bought their backing plate I was too lazy as in could not find the wrench to use it. So I am wondering if that backing plate would have made a big difference ?
__________________
2010 Lexus 250h Nebula Grey Pearl
2006 Jet Black BMW 325i
1969 Primrose Yellow 4.2 XKE
Largebore is offline
Old 06-18-2012, 12:34 PM   #2
Setec Astronomy's Avatar
Re: Megs mf system question
What backing plate did you use? Did you fluff up the fibers on the pad when they became matted down by brushing or blowing with compressed air?
__________________
"Spray it like you mean it!"
Setec Astronomy is offline
Old 06-18-2012, 01:00 PM   #3
BobbyG's Avatar
I don't think using Meguiar's backing plate is a make or break component. I use their pads on a Lake Country pad with decent results....
Priming the pad is very important..
Did you completely prime the pad then add 4 or 5 dime size dots?
About 13:30 on the Meguiar's Video
__________________
BobbyG is offline
Old 06-18-2012, 01:02 PM   #4
Divine Details's Avatar
Regular cleaning with compressed air is a must. It makes a huge difference. The megs backing plate is supposed to dissipate the heat better improving the performance of the pads. Also the Velcro is different.
Chad@Divine Details
Divine Details is offline
Old 06-18-2012, 01:38 PM   #5
Largebore's Avatar
Meguiars Microfiber DA Correction System - YouTube
Primed and ready to go...
__________________
Old 06-18-2012, 01:39 PM   #6
Largebore's Avatar
Quote:
Chad@Divine Details
Did not heat up really as they recommended a farily slow speed.
i had clean pads. just did one body panel and used the two pads in the pack to be sure they were clean.
__________________
Old 06-18-2012, 02:04 PM   #7
I guess I read the above too fast the first time. What compound, PowerGloss? PG and a yellow pad is probably going to make the Meg's MF system look unimpressive from a cutting standpoint.
The target market of the system is to get wool pads and rotary buffers out of the hands of production detailers. The MF system is pretty easy and foolproof two-step system and does a decent amount of correction while leaving an excellent finish on most paints.
__________________
Old 06-18-2012, 03:38 PM   #8
Largebore's Avatar
Yes, Powergloss
__________________
Old 06-18-2012, 05:00 PM   #9
RaskyR1's Avatar
What make/model car were you working on. Power Gloss and a Yellow LC pad may yield more cut when making equal passes to Meg MF/D300, but the finish it leaves will likely be horrid and will require more effort to finish down. Technique is pretty important with the MF system. Speed 4 on the GG6, moderate to heavy pressure, SLOW arm speed, and keep your section small.
BP is not a huge issue, but you may see more heat generated with non-Megs backing plates. I'm currently using a Mirka plate with mine.
__________________
Quote:
Originally Posted by CieraSL View Post
http://Raskysautodetailing.com/
RaskyR1 is offline
Old 06-18-2012, 06:06 PM   #10
Largebore's Avatar
Jet BLACK BMW
I have no problem with Menz and yellow pad. The finish is great... I just wanted to avoid using it too much too protect the clear coat.
Technique with MF was just as you described.
__________________
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Megs MF System or Optimum MF system? Hellspawn Auto Detailing 101 9 05-11-2012 06:37 PM
Newbie question sealer megs roth79 Ask the Expert featuring Mike Phillips 3 05-09-2012 08:33 PM
new megs DA system, layering? Dude2k Ask the Expert featuring Mike Phillips 1 03-21-2011 07:29 PM
Review: Meguiar's DA Microfiber System RaskyR1 Product Reviews 55 02-21-2011 08:51 AM
Paging Mr Phillips: Megs APC vs APC+ Question Deep Gloss Auto Salon Ask the Expert featuring Mike Phillips 9 07-06-2010 02:58 PM
» May 2013
» Car Care Brands
