Results 1 to 8 of 8
    Sep 2011
    Tampa, FL
    104
    New gloss black steel wheels - Opti-Coat?
    I will be receiving a new set of Cragar Soft 8 steel wheels next week. They are gloss black powder coated wheels. From what I have read, they clean up very nicely. That said, do you think I should Opti-Coat the wheels before having them mounted?
    Super Member TroyScherer's Avatar
    Sep 2009
    Ohio
    1,912
    Re: New gloss black steel wheels - Opti-Coat?
    It's can't hurt. Opti-Coat would be a great layer of protection especially if you already have some.
    Super Member LuxuryMobile's Avatar
    Feb 2009
    1,532
    It would sure make cleaning and caring for them much, much easier. I say go ahead and do it.
    Luxury Mobile Auto Detailing
    Pensacola & Orlando
    407.625.1480
    Sep 2011
    Tampa, FL
    104
    Sorry, guys... I forgot the main reason I wanted to ask. If I do decide to apply Opti-Coat, would I need to do any prep work since they will be new and in the box when I get them?
    Super Member C. Charles Hahn's Avatar
    Aug 2007
    Lansing, MI
    3,103
    You should still clean them up first, since there's no telling what sort of oils may be on the surface from the factory. Just a quick wipedown with OPC, or CP Eraser isn't a big deal.
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
    Super Member shoeless89's Avatar
    Jul 2010
    Union, KY
    1,985
    I would still do an IPA wipe down or something like that. And check the surface for contaminants. Who knows where they were sitting and for how long
    Sent from my DROID Pro using Tapatalk
    Rule 62: Don't take yourself to d*mn seriously
    Cincinnati, OH
    Shawn
    SELF BANNED
    Oct 2011
    Chicago Area
    394
    I'd use one of the fine line of Meguiars Products like Ultimate Quick Wax...1 easy spray and you are done.
    But, I'd wait til the new SEMA Products are released..you might find some new great stuff. You have to be careful you dont ruin those new wheels!
    Bacon
    Junior Member VGA No.1's Avatar
    Feb 2010
    Australia / Philippines
    34
    Steps in Opti_Coat 2.0 Application:
    1. Buff or then polish wheels to bring out its final gloss (Depending on how you want to accomplish doing these)
    2. On your last step for protection / gloss enhancer use OPT Opti Seal.
    Just spray on then wipe off on new microfiber towel. (Depending on choice)
    3. Wash wheels with water then spray Meguiar's APC- all purpose cleaner on 25/75 water dilution. Thats 25 APC then 75 Water. wipe down with microfiber sponge. Then rinse with water.
    4. Dry wheels
    5. Spray IPA alcohol. Make sure its 15-20% including on water dilution. Ex. you have IPA 40% just mix it with 50% water to make it 20%
    5. After spraying 15-20% alcohol, wipe it down with clean microfiber towel. make sure wheels are perfectly dry.
    6. Apply Opti_Coat 2.0 using foam applicator or any applicator. (was using the one girls use to remove there make up on there face. I forgot whats its called. a face applicator maybe )
    7. When applying Opti_Coat 2.0 make an up and down pattern then after you could do left and right pattern. make sure you don't miss a spot and make sure its not to much other wise you'll be wasting the product.
    8. Wipe down slowly with a clean microfiber cloth.
    9. Let it dry at least 24hrs - This is for curing period which is the most important of all. (Do not touch or wipe down)
    10. Wipe down with OPT Opti Seal on microfiber cloth.
    11. Install it on your car
    When applying OPti_Coat make sure your in a dust free room temperature enclosed area. Same procedure i recommend on applying to a car's paint. Good luck
    Hello im VGA
  1. Trying Opti Coat Gloss on wheels but cant see it
    By UnhandledException in forum Auto Detailing 101
    Last Post: 12-13-2017, 03:42 PM
  2. Old, Original Opti-Coat vs. Newer Opti-Gloss vs. something else ??
    By Jed Clampett in forum Auto Detailing 101
    Last Post: 02-22-2017, 08:33 AM
  3. Replies: 16
    Last Post: 09-02-2016, 11:07 AM
  4. anyone use opti-gloss on matte black wheels?
    By 07rs in forum Auto Detailing 101
    Last Post: 03-17-2015, 10:56 AM
  5. Opti-Coat Over Blued Steel Firearm
    By KneeDragr in forum Off-Topic
    Last Post: 03-07-2013, 05:34 PM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
