Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Senior Member rider9195's Avatar
    Jun 2011
    Ulster County, NY
    3,227
    Brake rotor rust
    After picking up my new car I noticed on the drive home the rust on the rotors did not come off. I saw it at the dealer and thought it would just come off while braking...well it didn't. So now I'm wonder what will remove the rust. I have heard of people using steel wool or sandpaper and some brake cleaner. Does anyone have any other suggestions?
    P.S.- Trying to find products that I can find locally.
    Ryan 2006 Volvo S60 R
    Senior Member pixelmonkey's Avatar
    Sep 2010
    Oklahoma
    532
    Re: Brake rotor rust
    drive the car some more and the rust will go away. just takes some time.
    chris<pixelmonkey>:D
    Jun 2011
    Ulster County, NY
    3,227
    It's being driven for the next 5 days. So I will have to see how much does come off.
    Senior Member Buckskincolt's Avatar
    Aug 2009
    OR
    1,585
    If you are talking rust on the rotors and not the wheels, if you get it off it will come back. the type of metal rotors are made of rust very easy so any time the car sits it will rust. here on the Oregon Coast we get rotor rust over night.
    "Labor is prior to, and independent of, capital. Capital is only the fruit of labor, and could never have existed if labor had not first existed. Labor is the superior of capital, and deserves much the higher consideration." Lincoln's First Annual Message to Congress, December 3, 1861.
    Newport, Oregon USA!
    Senior Member Y2KSVT's Avatar
    Jul 2010
    Leo, IN
    815
    There is still surface rust on the face of your rotors? Do you have a picture you could post? How new is the car? If the brakes have been properly broken in, you should be able to do a couple of full pressure brakes from 60mph to 20mph. Just be careful where you're doing this to avoid unsuspecting drivers having to brake unexpectedly behind you. An open stretch of highway with nobody around is best. I personally would not sand my rotors or use any chemicals that could eat away at the brake pad material. I believe Sonax makes an all wheel cleaner that lifts impurities in wheels. That could possibly work on your rotors.
    Mark
    Senior Member CrownKote's Avatar
    Sep 2009
    Colorado
    895
    I get rust on my rotors overnight here in CO too... it is a thing we all have to live with...
    The only rotors that have seen that don't rust are the full carbon ones and they are not very practical for a DD financially or otherwise...
    If you get some zinc plated rotors they won't rust as much until the zinc is worn off...
    Galatians 6:17
    Hello my name is Chris
    www.crownkote.com
    Senior Member Ted S.'s Avatar
    Feb 2011
    Tennessee
    1,746
    CRC makes a brake cleaner, but unfortunatly, it doesn't remove rust. Harsh stuff, really...
    I would worry about it unless the rotors aren't braking properly. You can replace your rotors down the road with some premium drilled and slotted, zinc coated (avoid any made with cadmium; cadmium is a toxic metal to us, last I checked) ones. Just make sure you get the ceramic brake pads. Big money, but you may find that they do not rust as easily?!?!
    Sep 2010
    Oklahoma
    532
    see the attached image.
    "1" is where the rotor is squeezed by the brake pads. this area is prone to rust over some time.
    2 is the portion of the rotor that CAN have some rust problems that can be irritating.
    3 is the portion that can also have rust.
    if you are having issues with rust on "1", drive the car more, or keep it stored in a low humidity environment.
    if you are having issues with rust on 2 or 3, remove the rotors and have them powder coated in the color of your choice. the painted portion that the brake pads ride on will wear away the paint in a short amount of time. be cautious when driving with the newly cured & coated rotors!
    Most shops will tape off the portion of the rotor that the pads glide across, however they usually like to cover 1/8" to 1/4" with paint to be sure the rust doesnt return.
    Even that little bit will take a few miles of driving before the painted portion has worn away to reveal metal the pads can "bite". before the pads can "bite" the rotor, the response and strength or your brakes will be equal to that of a 74 pinto; dont expect to stop if a ball bounces in front of your car, so choose your route accordingly.
    hope it helps!
    Attached Thumbnails Attached Thumbnails Brake rotor rust-rotorwithrustjpg
    Feb 2011
    159
    ^ that.
    If the rust isnt in the area of where the pads rub (it most likely isnt, or else your pads arent actually stopping the car), you can look into powdercoating, or maybe zinc-coated rotors. I got rotors with a black zinc coating on them for my wifes car, and the edges and the "hats" (the portion where the lug studs come through) have never rusted.
    You'll get some rusting where the pads rub from humidity, or even just washing your car, but a few uses of the brakes should make that go away.
  10. #10
    Jun 2011
    Ulster County, NY
    3,227
    Thanks for the advice everybody! I ended up using steel wool to remove the rust and then found out that some how the calipers aren't clamping the brake evenly. So that explains why the rust wasn't coming off. Ended up taking the wheel off and cleaning everything in sight. Very clean now
  1. BMW wheel rotor rust
    By rms64 in forum Auto Detailing 101
    Last Post: 12-17-2014, 10:18 PM
  2. Brake rotor rust
    By TurboTodd in forum Ask Mike Phillips your detailing questions!
    Last Post: 05-14-2014, 10:13 AM
  3. Brake Rotor Rust
    By jayshut11 in forum Ask Mike Phillips your detailing questions!
    Last Post: 11-02-2013, 03:41 PM
  4. Meg APC+ Brake Rotor Safe?
    By dc5itr329 in forum Auto Detailing 101
    Last Post: 05-30-2009, 06:42 AM
  5. brake rotor cleaning
    By MARK928S in forum Auto Detailing 101
    Last Post: 02-09-2009, 11:00 AM
» April 2017
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
