» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 06-11-2012, 09:35 PM   #231
Re: My solution to $150 foam guns...
man i was just looking at these foam cannons at home depot....was bout to drop 120 .....you just saved me a hundred bucks
dajuanNonly is offline
Old 06-12-2012, 12:58 AM   #232
Dynamic_Detailing's Avatar
Quote:
This... Green Earth G-Foam Blaster for 4,000 Psi Pressure Washers AGPWF04 at The Home Depot
IS NOT the same as this... MTM Hydro 14.0263 - Long-Range Detergent Foamer Attachment
Just so you know
__________________
ALL the Details
Dynamic_Detailing is offline
Old 06-16-2012, 01:55 AM   #233
Member
Quote:
Originally Posted by poweraid View Post
with all the different brand electric pressure washers they may all have different fittings and adapters needed. what brand pressure washer u got , and then can u show pic of the fitting end ? if u don't have a pressure washer yet u best bet is to get one that has quick release on end to change tips and such . quick release similar to air line fittings but they are not the same . most has p.w have these type and electric depends . a better brand or more pricier brand may have that quick release tips that a foam cannon can attach right to it with no adapters. I have a greenworks brand from lowes . hope that helps a little
I have this one, in this thread
AR Blue Clean Pressure Washer question(s)
Stride is offline
Old 06-16-2012, 08:25 AM   #234
poweraid's Avatar
pm sent
poweraid is offline
Old 06-16-2012, 09:03 AM   #235
I just received the last part from AR Blue's website, the bayonet adapter, so I haven't had a chance to fit it on yet. But here's the picture you requested... I don't know where to go from here, kind of scratching my head.
__________________
ALL the Details
Old 08-19-2012, 01:25 AM   #236
I have an older Husky 1750 psi pressure washer which uses the Bosch Style connector. I would like to order the MTM Hydro, or the G-Foam Blaster, but cannot figure out how to get them to connect. I don't want to order a foamer that I can't use.
AG sells the following adapter. Will this directly fit either of the above foamers?
Bosch Pressure Washer Fitting
Apparently the G-Foam only uses a 1/4" quick disconnect, but the MTM can use 1/4" quick disconnect, or M22 threaded in place of the 1/4".
cam94z28 is offline
Old 08-20-2012, 04:09 PM   #237
I'd love to get a power washer and one of the foam guns, but it seems not everyone has the same results based on soap, pressure washer, etc. Blah, maybe I'll stick to 'the mitt'
CrazyJay is offline
Old 09-15-2012, 06:54 PM   #238
Can someone explain how this is better than washing with the two bucket method? It seems to add an extra step since you're foaming the car and rinsing it off then foaming it again then washing it with two buckets.
matryx is offline
Old 09-15-2012, 11:41 PM   #239
Joe@Superior Shine's Avatar
The home-depot foamer lasted me maybe 20-30 uses then it petered out. I still think I got my monies worth.
Joe@Superior Shine is offline
Old 09-15-2012, 11:47 PM   #240
ihaveacamaro's Avatar
Quote:
The foam is supposed to lift up dirt, and when you wash them off you have less dirt on the car. Less dirt when hand washing is supposed to mean less swirls.
Yeah, it adds a step. Or if you're lazy like me, apply opticoat. Then foam car. Rinse car. Dry car. Done
ihaveacamaro is online now
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
I hate the winter... 93fox Off-Topic 66 01-26-2013 09:29 AM
Foam guns...really worth the extra step? silverfox Auto Detailing 101 9 11-21-2010 11:28 AM
The different types of foam formulas in the CCS Smart Foam Pad Line Mike.Phillips@Autogeek Wool & Foam Buffing Pads 2 10-05-2010 09:49 AM
Foam Pad Selection Criteria TOGWT Auto Detailing University 2 03-25-2008 09:49 PM
It's Finally Here!! DP Xtreme Foam Formula Meghan New Car Care Products 23 07-18-2006 06:53 AM
» June 2013
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
» Car Care Brands
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
