| Re: someone had a fix for broken E-Z Detail/Daytona brushes...can't find it!
thanks guys!
yep, i think i'm going to buy a cheapo brush from home depot with a soft plastic handle, cut the handle to length and try to epoxy it in there. the reason is, the length of the brush stem will effectively be shorter than "stock" since i'll have to insert some of it in the handle. i mean i could use a wooden dowel that is longer than the OE handle too but i think the plastic would be more resilient.
the problem is it'll probably eventually break at the new insertion point but whatever.
__________________ '09 Mercedes-Benz C63 AMG / '07 Si sedan |
