Tape??
What tape you guys use to tape trim off while
Re: Tape??
I use either the blue or green painters tape. Both work well peal off nice end easy...
Re: Tape??
Like the 3M at WM?? In the house paint?
Re: Tape??
Yes, exactly.
Generally I pick up several different widths and mostly from Lowe's. Lowe's has a wider selection so it's a one stop shop........
I think that the best is the 3m automotive green tape. Mostly because its flexable, meaning you can bend it around headlights without having to put so much pieces everywhere. Its the only tape ive used so far that is flexable to a point when you can makena circle with just one strip.
Hi !
Re: Tape??
This is what I use. I hate the green 3M tape because if you get IPA or ONR on it, the adhesive smears all over the section that you're wiping off. That sucks
Re: Tape??
I used Meguiar's tape for the first time the other day. Sticks where you want it to and peels off clean. I've had occasions where the blue tape just didn't want to come off some places.
TL
I use the blue tape but for some reason the color started to transfer in to my towels I guess when I was doing the ipa wipe.
But it sticks very well if you place it right the first time.
"You can help create your own luck, you can make things happen through hard work and intelligence."- Donald J. Trump
Re: Tape??
From 3M-
Scotch® Automotive Refinish Masking Tape 233+
Designed expressely for the professional auto refinish painter. Conformable, hugs curves and contours. Goes on quickly and easily, sticks at a touch and stays put. Every feature perfectly balanced to give outstanding masking results.
Highly conformable, provides the best adhesive transfer resistance, hugs curves, contours and provides outstanding paint lines. Goes on quickly and easily, sticks at a touch and stays put. Perfectly balanced to give outstanding masking results.
This unique, green colored tape has excellent conformability, Transfer resistance, and is resistant to bleed through. 233+ is also has better UV resistance than traditional masking tapes.
The green one.
Re: Tape??
Yep, I use the 3M green automotive tape. Buy it at Walmart. I n fact, time to restock.
Kevin
By Washburn in forum Auto Detailing 101
Last Post: 06-18-2014, 07:10 PM
By Scubadaddy in forum Auto Detailing 101
Last Post: 03-24-2014, 10:11 AM
By Toy_Cam_Ed in forum Auto Detailing 101
Last Post: 06-26-2012, 07:46 AM
By DaC in forum Auto Detailing 101
Last Post: 11-06-2011, 07:59 PM
By Tonya in forum Auto Detailing 101
Last Post: 07-23-2007, 10:20 PM
