Best method to apply PB Black Hole
Just Rec'd PB Black Hole what do you think is best way for application by machine(flex) or Hand ? If machine what pad CCs white or grey what speed to to work in? how long b4 you can top with PB sealant then Natty blue ?
Re: Best method to apply PB Black Hole
I used it with a finishing pad and a PC. Using the flex I would use a finishing pad (grey) and one of the lowest speed settings. I believe you can top it with a sealant shortly after the glaze but you'll need to wait to add Natty's 24 hours after the sealant (EX, or Ex-P?).
machine as offered, no need to go full blast. Steve infact offered at DFIII that it is compatible with sealant or wax based upon users choice.
I'm no expert, but my experience is follow directions on the bottle. Apply thin, by hand or PC. I use a PC with a gray or blue pad on a low speed. After it hazes I wipe off with an MF.
You can top it right away with sealant or wax.
_____________________________________
"Dogs in cars again. Going away. Going away fast" - P.D. Eastman, Go, Dog. Go!
It's good stuff if you use it correctly. Speed 1 or 2 with the Flex 3401 and a gray pad. Do not work it in too much as you want it to "sit" on the paint. You can apply wax or a sealant right after buffing off the haze.
I used it with a gray pad, speed about 2-3 with my griot's.
Let it haze and remove with a mf
Ed
Moderator/Consultant for Autogeek.net
To achieve excellence, excellence cannot be rushed. Technique is just as important as the product used.
While my approach takes more time, the results are far superior.
I apply speed 2 or 3 via black LC pad (5.5in).
I really like using it, it noticeably makes the paint slick and smooth to the touch, not to mention it darkens the color as well. I also like the fact that it fills in minor imperfections.
Do you just spread in one pass or go over multiple times? I used it just once and it seemed to dry out quickly even at speed 1 or 2.
By uhohitsstevo in forum Auto Detailing 101
Last Post: 04-29-2016, 08:33 PM
By Bicycle in forum Auto Detailing 101
Last Post: 08-05-2015, 09:23 AM
By ALLN1WASH in forum Auto Detailing 101
Last Post: 01-04-2011, 09:56 AM
By Xcessiv in forum Auto Detailing 101
Last Post: 03-15-2010, 03:16 PM
By alowe in forum Auto Detailing 101
Last Post: 05-11-2008, 01:31 PM
