Results 1 to 10 of 10
    Super Member jcarson112's Avatar
    Jul 2010
    Tacoma, WA
    206
    Trouble finding defects with white paint?
    Not anymore...
    Stumbled across this around Halloween when I was dinking around with my work light and colored bulbs. Just change the light color you're working with.
    My tests suggest that orange works the best. This one is shown on my old white wagon (doesn't get treated like it should) using the street light to illustrate the benefits of off colored lighting.
    Feel free to comment or discuss other ideas...
    Jeff C.
    Nov 2010
    philippines
    37
    Re: Trouble finding defects with white paint?
    for light colored surfaces, it's about getting an intense reflection of the light source and as little light thrown by it on the side so if you move the light source away, the light thrown does not reach the surface as much, easier to see the swirls.
    i need the proper lighting terms/words.
    i haven't given this much time. you may want to try to pipe the light through a long barrel/tube to minimize light on the sides (ambient) and use a large reflector so the reflection of the source is useable, large and intense enough even at a distance to show the swirls at least on a quarter of a panel
    Nov 2010
    1,337
    good tip.
    I have an Ibis White B8 S4, and the most effective way to easily see defects on the paint is to use the dark room method.
    I close the garage door with all the lights off and only use my halogens. By doing so the flaws will pop right out of the paint.
    Even if you have the brightest swirl finder, you will not see the defects easily if its being drowned out by outside light. dark room polishing is the easiest way to work on a white car.
    Nov 2010
    philippines
    37
    i just don't have that space. i'll try to make one although it's a lot for someone who does this only for one's self (not a biz).
    i take you have a wide garage where you can prop the halogens for away enough not to flood the panels with their light. since the light from source should significantly be greater than the light spread from it
    an analogy may be a big showerhead with a center and shower spray
    ___||___
    if the shower is sprayed on a pool, the pool surface will be riddled with small droplets all over with their waves bumping one another, while if it's just the center spray, there'll be concentric waves (i assume) from where the center spray hits the pool surface -- the desired effect.
    that's most of what i got, cheers
    Super Member Shane731's Avatar
    Dec 2009
    Madison, AL
    3,498
    An LED flashlight works very well on light colored paint. I have a Fenix P3D. Particularly on light colored paint, an LED will concentrate the light, rather than reflecting it back in your face like a Brinkmann can.
    LED on white (has been polished with TSR and an LC 5.5 inch orange on G110v2 - you can still see some very light swirls and some RIDS, which can be seen to the left of the light)
    LED on beige (showing swirls before polishing)
    Shane
    Nov 2010
    philippines
    37
    way to go with the power efficient LED. there is a way to find swirls with different light sources. it is harder to find swirls in a well maintained car but it's more pain to see those spiderweb swirls on your car
    i'd like to find power efficient lights that are similarly capable like jcarson's pics above. that covers a big part of the hood .
    Super Member ihaveacamaro's Avatar
    Jun 2012
    Ft. Lauderdale, Fl
    3,048
    woah, that orange light is showing everything!
    Sorry for bringing a necro thread back lol
    Nova College of Dental Medicine Class of 2017
    Please check out my detailing YouTube channel: http://www.youtube.com/user/roshan517
    Super Member Bill1234's Avatar
    Apr 2012
    New York, NY
    2,647
    Led is great as it does show defects but produces less heat which is good for the compound to not dry up
    Bill 1234
    2004 audi a6 quattro (traded).
    2015 Ford Escape 2.0l ecoboost 4WD
    Super Member vegas911gts's Avatar
    Sep 2012
    557
    Nice tip with the orange bulb. Thanks!
  10. #10
    Aug 2015
    68
    Quote Originally Posted by jcarson112 View Post
    Not anymore...
    To replicate the "orange light" concept, consider this..... if using a flashlight as your swirlfinder, most of them have a removable lens. One could use a photo / lighting gel to change the lighting color (such as 1 full CTO - an orange gel) under the lens. If it's a cheapo flashlight, one could even use a colored Sharpie to color the lens (a rather permanent conversion). A less destructive and more creative alternative - I saw that the cap from a plastic jug slips over the front of my flashlight. I could use a hot Exacto knife to cut a circle in the cap, then attach a colored gel covering the hole. (For a temporary / removable option)
    Just brainstorming - haven't tested it yet though.
  1. Need help finding a colorful polish for white car
    By JonRC in forum Auto Detailing 101
    Last Post: 03-18-2016, 06:03 PM
  2. Trouble Shooting BMW M-Coupe Wheel Defects
    By Ohio Detailing in forum Auto Detailing 101
    Last Post: 09-15-2013, 09:42 PM
  3. Trouble finding the sweet spot
    By Attn2Detailz in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 07-12-2012, 02:36 PM
  4. Replies: 2
    Last Post: 07-13-2011, 05:12 AM
  5. Trouble finding the right pads for PC7424
    By pnut in forum Ask your detailing questions!
    Last Post: 09-17-2009, 12:39 PM
