Re: Toro Leaf Blower for Car Drying
I use a leaf blower intentionally leaving some light water droplets, and then I spritz with a detailing spray and wipe/blot with a guzzler. Its adds gloss and enough lubrication to avoid scratches, and will remove the water marks too.
Thanks for the suggestions.
So how big is the lip opening when using the 5MPH lung method?
My shop vac was used to clean up drywall prep so it sprays little white particles at start up. Not a good idea for a car dryer.
Probably back to an air compressor or cordless leaf blower with the little metro hand held doesn't have the output.
Not sure if anyone's tried this out, but Craftsman has a 18V hand held vac/blower as part of their C3 system for about $40. I need a new cordless drill so I was going to look into this for the crevices. Anyone happen to try one?
I'd be interested to hear your experience if you go down that road.
I used mine shopvac for drywall as well...but if you disassemble the motor portion there should be a filter in there that is probably caked with drywall (i know mine was). After cleaning it all was clear .
If you then use it as a vac after, dirt will ofcourse get back in the filter...but if you turn the blower on away from the car for 20 or 30 seconds it blows all the loose dust out and can then be used on the car
I didn't disassemble the motor unit to clean the coarse filter at the base. I noticed that even after blowing the filter out with pressurized air, particles would fly when I turned in on initially. Maybe I will take it apart and see what I can do.
Thanks!
Thanks!
No problem . Gonna warn ya, i bet its nasty in there...I used a 5 Gallon bucket of warm soapy water and by the time i was done with the filter the water was black.
I use a Craftsman vacuum with the blower. Works great IMO. The blower is rated at 265 mph.
the 150 mph weedeater leaf blower from walmart works fine and is light enough to hold in one hand while using a small waffle weave or micorofiber towel in the other to blot any water droplets, and inexpensive at only $30 as well...
Last Post: 08-16-2017, 11:30 PM
Last Post: 05-01-2017, 07:09 AM
By Saluki2003 in forum Auto Detailing 101
Last Post: 12-28-2013, 09:32 PM
By Nate3420 in forum Auto Detailing 101
Last Post: 06-26-2013, 10:53 AM
By Plan b Detail in forum Auto Detailing 101
Last Post: 07-25-2011, 05:55 PM
