» Autogeek Online Classes | |  | |
02-20-2010, 10:41 AM
#1 | | Senior Member
| Can ONR really be used WITHOUT causing marring on black paint?
So a few years ago (2005) when QEW was all the rage I figured I would give it a try. I did one panel and was horrified at the marring it was causing. I threw the water out and proceeded to do an old fashion 3 bucket 6 mitt wash, followed by a blot dry with waffle weave microfiber drying towels. Since then I have not tried any kind of rinseless wash.
Now that I have a 13 month old, and time is hard to come by I am considering trying the optimum no rinse car wash this time. Which leads me to my question.
__________________
2004 Pontiac PBM GTO
11.78 @ 124
02-20-2010, 10:44 AM
#2 | | Senior Member
| Re: Can ONR really be used WITHOUT causing marring on black paint?
If it is really dirty, I would take it to a automatic spray wash to get the big stuff off. Also, you can buy a sprayer, and spray the car down(with ONR mix) in the garage to lubricate the dirt before wiping.
To answer the question. Yes, it can be done, if done properly.
02-20-2010, 10:52 AM
#3 | | Senior Member
I think any rinseless wash product like ONR can be used improperly such as a poor wash media or technique, etc so it is not always the product's fault but the tools and techniques used.
__________________ Al
The Need to Bead |
02-20-2010, 11:15 AM
#4 | | Senior Member
I have 2 black vehicles and do ONR as much as traditional washes. If it's real dirty or the wheels etc need a good cleaning I'll do normal wash. If I clean up my car real good, then it rains or gets hit with sprinklers etc, then an ONR wash is perfect.
02-20-2010, 12:14 PM
#5 | | Senior Member
Can you share the procedure you use.
__________________
11.78 @ 124
02-20-2010, 01:16 PM
#6 | | Senior Member
Never had an issue with ONR. If its really dirty, squeeze out more solution.
02-20-2010, 01:20 PM
#7 | | Senior Member
Here is what I do to stay safe. I go to the car wash and pressure wash all the dirt off and drive back home in the garage and use the two bucket method. I use the grit guard in the water bucket and ONR the other without the grit guard. Now, to even stay safer...... I use the ingredients for a QD from the ONR and spray on each fender work on just to stay even safer. Doing this will ensure you are not causing any marring.... just change your rags often and use hot water.
__________________
2006 Lincoln Zephyr- 28% Solar Guard Charcoal tint, Pioneer DVD player/In-dash, Boston Acoustics component 5x7's
Future Ride- Either the 2008-09 Mustang Shelby GT or base Camaro SS
02-20-2010, 02:34 PM
#8 | | Senior Member
While I don't have a black car, I have used rinseless washes on a white one and 2 red ones for several years without causing a bunch of marring.
One thing I might mention, I have used ONR, DP RW&G, and QEW, all with good results. I would have no reservations using any of the three on my vehicles.
__________________ Charles The Rainmaker |
02-20-2010, 08:02 PM
#9 | | Senior Member
Yup, I have not used anything else on my car in a year or so and it does not add any marring. It did take me some time to get my technique downpat which involved making my working area much smaller and going from top to bottom in a few extra steps. All in all, it can definately be done and leaves great results when used properly.
Ps. I like the Cobra bone and Chenille wash media with ONR, using the two bucket method is the most crucial part to a rinseless wash however.
02-20-2010, 08:39 PM
#10 | | Member
I think that ONR is the same as using any other car wash soap. It's not the bubbles that make your car clean and safe from marring, it's the media used and the lubricity of the wash. ONR doesn't make bubbles, this makes some people think it won't be as good. I've never used anything but ONR to wash my car and it has never caused a problem. I have even washed my vehicle scrubbing crusty mud off and it came right off. I've done things with ONR that would make alot of people cringe.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » May 2012 | | S | M | T | W | T | F | S | | 29 | 30 |
| 1 | 2 | » Car Care Brands | | | |
