car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
» Official Detail Fest 2010 Information Thread!!
» Current Poll
How do you prefer your information?
Paper Handbook - 24.77%
27 Votes
DVD - 11.93%
13 Votes
Digital PDF Download - 63.30%
69 Votes
Total Votes: 109
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 02-07-2010, 06:19 PM   #1
02blackout's Avatar
Misc ?s. 105/205 and Tape
When can I tell if I'm done using 105 and its time to use 205. Basically, how can I tell if its a job for 205? Is it just if the swirls are fine?
I accidentally ordered grey pads intended for 205 instead of white ones. Ive heard using 205 with grey works fine as well.
Since my wheels are painted black, should I use OJ/105 then grey/205 on them or just use straight grey/205 til the light scratches are out.
Taping: once done taping, what do I do to remove the tape lines?
Thanks guys
__________________
“Wow. I can't even imagine how much time you have to spend keeping that clean... I'd rather have a pile for a daily driver than try to keep that clean driving it all the time.” –JeffSeb
02blackout is offline
Old 02-07-2010, 06:42 PM   #2
joshs07redss's Avatar
Re: Misc ?s. 105/205 and Tape
M105 works very fast. I've just started getting the hang of it since switching from Menzerna. What will you be using M105 with? Rotary or DA? Wool or foam?
For your wheels, I would try using some M205 and a microfiber towel to polish them out. You always want to start with the least aggressive and then work your way up if it's needed.
After you tape off a section for a 50/50 shot, just polish over the tape line. If you overlap a little bit, that is fine.
__________________
Be sure to check out http://www.autogeekonline.net/forum/...-everyone.html. All pictures are welcome!!
joshs07redss is online now
Old 02-07-2010, 07:31 PM   #3
02blackout's Avatar
Ill be using foam pads with a PC! Could I use Klasse AIO instead of 205 or wil that not do that job?
__________________
Old 02-07-2010, 07:36 PM   #4
Harleyguy's Avatar
If you have 205 use the 205 it's made to go with the 105 and the end results will be well worth it .If all your swirls are gone or your happy with the results from using the 105 it's time to move to the 205.Just do a IPA wipedown before the next step.
__________________
2005 Corvette Z51
2008 Infinti EX35
2004 Ford Sporttrac everyday ride
2008 Saturn vue
2004 Roadking (sold)
Looking forward to DF 2010
Harleyguy is offline
Old 02-07-2010, 07:38 PM   #5
Quote:
I've never used AIO. If you have the 205, I would use that since it's a designated polish and not all-in-one product. Make sure that you have 5.5" orange pads at speed 6 to get correction with 105. I'm just getting used to its fast work time using a rotary. I'm not sure how it behaves with a PC, but I'd imagine it's about the same. Do you have any pads between orange and gray? Will you be following up 205 with anything?
__________________
Old 02-07-2010, 07:45 PM   #6
02blackout's Avatar
Quote:
While using my floodlights to see swirls, are ALL swirls supposed to be gone after using 105? Surely not, 105 is just to remove all the main swirls until just fine ones are left for 205, right? I'm just saying when do I know when to use 105 or 205. I have lots of fine fine swirls so can I just use all 205/grey?
I sadly dont have the white pads yet. But I've heard using a grey pad for 205 will work fine. I do IPA wipedowns after 105 and 205
__________________
Old 02-07-2010, 07:53 PM   #7
You need to start with the least aggressive first. Give 205 and gray a shot and see what it does. If you're happy with the results, then follow up with a less aggressive polish. If you're not happy with the results, then step up to 105 and orange. You always want to start of with the least aggressive combo first. You might want to invest in some white pads as they are better suited to follow up 105 I think.
__________________
Old 02-07-2010, 10:09 PM   #8
vorga's Avatar
I just did my 02 mustang GT last month with 105,205 PC. the swirls were really bad from up to 2ft away (and i mean bad ) but at 5 ft the car looked great. i used 105 and orange pad 2 passes about 1 minute per pass was about the max working time i could get out of 105. 18inx18in max size bolcks . this took about 6 hrs and alot of effort to get rid of the swirls and deeper scraches . Deeper scratches took more passes . Then i followed up with 205 white pad .This went alot faster than 105 and easier about half the time . i then used michine glaze #03 (probly a useless step but wanted the nutrients #03 for the paint) Then finished with Maguiers carnuba wax #26 . and the black GT probly never looked so sweet. Now there was some spots i could of worked more but i plan on doing again once it warms up . Now i just bought this car about 4 months ago so i am just finding out how much i hate ford clearcoat . It is so easy to swirl (lightly scratch) .I am allways doing touch up spots . Just as a reference if i lean against the car most likely i will be touching up the spot with 205 . What i learned is yes 105 is HARD to work with and takes alot more effort than i thought it would. But 105 is worth ALL the effort it takes . now when it worms up i only have a few spots that i will need 105 on. The rest of the car i will only need 205. And clean your pad often . i used 2 of each and still had to clean them a few times ( i did a full clean and set pad aside till i had to clean the next pad used rotery to spin the water out of the pads). Now my main problem is wiping down the car too much. The car is like a Dust magnet and i am starting to see some light swirling hear and there from me messing with it . But hay i want it to look its best at all times.
__________________
1999 BMW 323i
2002 Mustang GT
2004 Chrysler Town & Country
vorga is offline
Old 02-08-2010, 12:19 AM   #9
zinc02gt's Avatar
M205 leaves a little to be made up, especially on black. You need a finishing polish like P085RD or Ultrafina.
M105 will remove heavy swirling/scratches and will leave slight micromarring, but not much.
M205 will remove what M105 left behind, but again will leave smaller micromarring. This is where a good finishing polish comes into play.
zinc02gt is online now
Old 02-08-2010, 04:34 PM   #10
vorga's Avatar
I noticed that also 205 did not seem to finish off as good as i thought it would .(at least on my black mustng) i had Maguiers #03 to finish the car before waxing .
__________________
1999 BMW 323i
2002 Mustang GT
vorga is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Tape question astrogus Auto Detailing 101 2 10-08-2009 06:41 PM
Tape Glue removal Buckskincolt Ask the Expert featuring Mike Phillips 1 09-23-2009 11:07 AM
3M Tape Type & Typical Width?? - Polishing Preparation tenorplayer23 Auto Detailing 101 20 08-23-2009 01:42 PM
When and what do I tape? Tonya Auto Detailing 101 37 07-23-2007 10:20 PM
Tape off edges and panels every time? FMINUS Auto Detailing 101 12 05-16-2007 01:33 PM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Pinnacle XMT Series 360
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
