Hey guys,
Does anyone know how to fix cloth seats with cig burns or hole? Any good DIY repair kits out there? I need to know ASAP! Thanks guys...
Printable View
Hey guys,
I'm not sure of anything besides re-upholstery.
Take a razor blade and scrape the seats to remove some fibers and lint. Place a dab of super glue in the burn mark and place all the fibers you collected right on top to fill them up. Let the glue dry a few minutes and trim. Its not a perfect fix but it makes things look a lot better and cheaper than reupholstering.
Hmmm good idea... I will maybe try it. Has anyone ever used a DIY repair kit?
I went with Dr. Vinyl. They're a franchise, and I believe they'll come out to your home and fix it. I had a couple burn holes in my driver's seat that the previous owner had left (he was a smoker, but he only had the car for a couple months). I think it cost about $30 to get those few holes repaired. I went to Dr. Vinyl's website, and came up with this contact info for Dr. Vinyl franchisees in KY:
Linda and Mike Hook
Dr. Vinyl of Louisville, KY
(502) 447-6422
Robert Popplewell and Donald Allen
Dr. Vinyl of Central Kentucky
(606) 787-0259
Here are a couple pics of my seat. You can kinda see where the holes were. Maybe not the best fix, but better than a couple holes in the seat.
http://meguiarsonline.com/forums/pho...m/P5150453.jpg
http://meguiarsonline.com/forums/pho...m/P4280378.jpg
Hey Ciera.... It is actually for a customer car.... not mine! But thanks...
and also..... thanks for the suggestion guys. Do you actually take a razor blaze used for shaving or just the blade alone (like the one used for box cutters?) Anyways... I will give this a try! Should I scrape the burnt fibers around the edges first? Thanks again
Fabric Upholstery Repair Kit from Business Supply ... I was going to give this a try too...
You'll want to use a box cuter razor. Yes you'll want to scrape the burnt fibers out first to have a good base. After you've applied the glue dont press the fibers down hard. Just place them on top and lightly pat down. Let dry and trim. Repeat if necessary.
Its similar to this process but your not gluing a piece of fabric down but the fibers themselves.
[ame=http://www.youtube.com/watch?v=5zYCsiA0N5I&feature=related]YouTube - How To: Repair Carpet Burns[/video]
