Quote:
Originally Posted by 360_detail Wow buddy I am completely impressed beyond belief at your interior work. Absolute A+!!
One thing I have a lot of trouble with is door hinges. Your white vehicles door hinges look absolutely brand new!
Would you be willing to explain your process of cleaning that area? I seem to run into a lot of grease on those. What do you use chemical wise? whats the process?
thanks |
I can tell you what I use on my white Toyota's door hinges.
First a spray of Gunk Foamy Engine Brite to cut through the thick grease that a previous owner had glopped on them. Took three applications and a lot of brushing to get the grease off.
Next I used a steam cleaner to spray steam (no cleaning agent) onto the drips of grease (turned out to be permanent stains.)
So I decided to paint the area. Got a small rattle can of the correct Duplicolor paint and a can of clear.
Used a 3m pad to rough up the area then sprayed the area with prep to clean it.
Taped off the area and hit it with three light coats of Super White. When dry gave it three coats of clear, just enough to make it look wet. Ended up looking like new.
As a matter of fact it turned out so nice I am going to remove the front bumper and repaint it myself. I hate parking rash!
