Bumpers Need Help
I have wihite scrapes and scratches on my black bumpers and surrounds of my BMW. I have used "Back to Black: and "Black Wow" and they do nothing to hide the white scrapes and scratches. What if anything is the solution ?
2013 Infinity JX35 White Pearl, 2009 BMW 528XI White
1969 Primrose Yellow 4.2 XKE
2002 Ford F-350 Powerstroke 7.3
Re: Bumpers Need Help
Originally Posted by Largebore
I have white scrapes and scratches on my black bumpers and surrounds of my BMW. I have used "Back to Black: and "Black Wow" and they do nothing to hide the white scrapes and scratches. What if anything is the solution ?
"Some materials and/or surface coatings don't lend themselves well to being abraded with the end-result looking good or looking original"
In order to remove a scratch out of anything, metal, plastic glass, paint, etc. You must remove material around the scratch until the upper most portions of the surface are level with or equal to the lowest depths of the scratch or defect you're trying to remove.
In the case of your rubber bumpers, abrading them in an effort to level the surface won't end up with the bumpers looking good so removing the scratches by removing material surrounding the scratches isn't an option.
The only other practical options are to,
If the problem is just paint transfer, as in some foreign paint is stuck on the surface, then it may be possible to remove the paint transfer with some type of solvent or cleaner just make sure the solvent or cleaner doesn't also dissolve the rubber at the same time.
Do you have a picture you can post?
A pic would help.
Is this unpainted ABS plastic or something else?
I have used bodyfiller successfully on bumper parts,but the difference being that they are painted,and the filler is covered. It does stay. Possibly a knock could dislodge it. I am infact doing one at the moment.
I think there is an ABS plastic repair kit,but I never tried it.
By stanza387 in forum Auto Detailing 101
Last Post: 04-24-2016, 08:17 AM
By detailerone in forum Auto Detailing 101
Last Post: 09-04-2014, 07:21 AM
By Eric@CherryOnTop in forum Auto Detailing 101
Last Post: 06-27-2014, 06:24 AM
By Largebore in forum Auto Detailing 101
Last Post: 06-15-2008, 10:27 AM
By Mike T in forum Auto Detailing 101
Last Post: 07-13-2006, 09:25 AM
