» Official Detail Fest 2010 Information Thread!! | |  | |
06-23-2009, 01:09 AM
#1 | | Junior Member
| 03 Ford Mustang multiple Paint chips - Help please
Hello all
Well I got SPlASHED with rocks/pebbles from haing to follow a truck down the freeway that didn't have a cover on his load. I got around him and let him know what I thought - I'll leave the details out.
So now I have one big chip on my hood and multiple smaller ones. The biggest one went right down to the metal of the hood. The others went down to what appears to be a light colored primer.
I bought a Pint of color from PPG today. They filled three aerosol cans up for me and said I could bring back the rest to put in cans if necessary.
I took my car to them to match it because I have a Satin Silver Mettalic color paint job and they had three different versions of it.
They said that they sold me what the called a single stage paint. I know nothing about body work or painting. I bought a 3M kit as well to get the basics like sand paper, a chip sander pen?, a tool to hook up to your drill, backing pad, orange pad for using rubbing compound and a buffing pad. it came with some 1500grit paper. They said some thing about flaring it out a bit which I don't know how to do. They told me to use 600grit sandpaper. I know the big chip is going to need several coats to build up to the level of the rest of the paint in that spot.
If any one knows of a Step By Step method for doing this job I'd appreciate it very much. I would have gone to a paint shop but I'm on disability still and money isn't plentiful at the moment. I want to do the best I can with for now.
Thanks in advance to any one that can help me with this process.
__________________
Not the fastest 270HP V6r w/4R70W, not the slowest that barks tires going into second! Love my cool SatinSilverMetallic automatic ride! Just need to see if I can get a better shine! So my son Joshua can take over when he reaches age. He want's a Harley already and not even big enough to touch the ground yet. He got a battery operated Hummer for his 4th Bday, I put some neopreme rubber around the plastic tires that didn't grip. |
06-23-2009, 08:37 AM
#2 | | Senior Member
| Re: 03 Ford Mustang multiple Paint chips - Help please
You need to clean the area and feather edge the paint chip area to blend smoothly with the surrounding paint so that it is very gradually tapered instead of having a hard edge where the chip meets the rest of the surrounding paint. Then you fill the chip with a little paint, and wait for it to dry, and then repeat until you have the touch up paint just above the level of the surrounding paint. Then, after a few days, like 4 days, you sand the touched up area down to be perfectly flush with the surrounding area of paint, and you polish it to match.You Use the 600 grit to feather edge the paint at first, and then you use the 1500 when you sand the touch up paint down. I suggest you have some 2000 and 2500 grit too, and maybe some 3000, to eventually finish off the paint chip area to polish it to look like the rest before you use polishing compound to bring up the shine.
One more thing. When you do all this, the paint still won't match the surrounding paint perfectly. There will be a hairline border where the chip area meets the surrounding paint, and the little metallic flakes that are inside the chip area probably won't exactly match either. When the paint was first sprayed, all of the little metallic flakes align themselves in a specific pattern, so that they all are fairly evenly spaced apart because all of the paint was wet at the same time and dried at the same time. The orientation of the flakes will be determined by the distance the spray gun is from the panel, the pressure of the gun, the angle of the gun, how thick the paint is in it, ect. When you apply touch up paint by hand, it is impossible to get the flakes in the paint to lay down in exactly the same pattern as before. Because of this, if you look closely when you are done, the paint won't match exactly perfectly. The only way to have the paint match perfect again is to repaint the ENTIRE panel. (Of course, I mean, RESPRAY the entire panel.) Good luck to you.
06-23-2009, 11:59 AM
#3 | | Junior Member
| Re: 03 Ford Mustang multiple Paint chips - Help please Quote:
Originally Posted by Blackthornone You need to clean the area and feather edge the paint chip area to blend smoothly with the surrounding paint so that it is very gradually tapered instead of having a hard edge where the chip meets the rest of the surrrounding paint. Then you fill the chip with a little paint, and wait for it to dry, and then repeat until you have the touch up paint just above the level of the surrounding paint. Then, after a few days, like 4 days, you sand the touched up area down to be perfectly flush with the surrounding area of paint, and you polish it to match.You Use the 600 grit to feather edge the paint at first, and then you use the 1500 when you sand the touch up paint down. I suggest you have some 2000 and 2500 grit too, and maybe some 3000, to eventually finish off the paint chip area to polish it to look like the rest before you use polishing compound to bring up the shine.
One more thing. When you do all this, the paint still won't match the surrounding paint perfectly. There will be a hairline border where the chip area meets the surrounding paint, and the little metallic flakes that are inside the chip area probably won't exactly match either. When the paint was first sprayed, all of the little metallic flakes align themselves in a specific pattern, so that they all are fairly evenly spaced apart because all of the paint was wet at the same time and dried at the same time. The orientation of the flakes will be determined by the distance the spray gun is from the panel, the pressure of the gun, the angle of the gun, how thick the paint is in it, ect. When you apply touch up paint by hand, it is impossible to get the flakes in the paint to lay down in exactly the same pattern as before. Because of this, if you look closely when you are done, the paint won't match exactly perfectly. The only way to have the paint match perfect again is to repaint the ENTIRE panel. (Of course, I mean, RESPRAY the entire panel.) Good luck to you. | Thanks for the reply. I'll just have to do my best for now and hope it comes out fairly good. If it doesn't, I'll have to save up some bucks and have it done by a shop. I hate driving it around like this. It's always looked so good before and of course this just had to happen right after I put a new front chin spoiler etc.. on - yikes !
__________________
06-23-2009, 07:36 PM
#4 | | Senior Member
Take a look at this i know some people who have used it with good results. paint chip repair and paint scratch repair
__________________ 2005 Corvette Z51 2008 Infinti EX35 2004 Ford Sporttrac everyday ride 2008 Saturn vue 2004 Roadking (sold) Looking forward to DF 2010 |
06-23-2009, 08:16 PM
#5 | | Senior Member
Originally Posted by Harleyguy | I almost got this kit, but decided to do it the old fashion way. I think any chip after filling, sanded and polished should be clear coated.
06-23-2009, 08:59 PM
#6 | | Senior Member
Originally Posted by Rsurfer I almost got this kit, but decided to do it the old fashion way. I think any chip after filling, sanded and polished should be clear coated. | I agree but i had a guy do a demo of the same type of kit used at my dealership and looked great.Well looked great then not sure how it would look in time.
06-23-2009, 09:42 PM
#7 | | Senior Member
Blackthornone is correct about the metallic flakes not spreading out evenly, thus causing an off color.
06-23-2009, 10:23 PM
#8 | | Senior Member
Originally Posted by Rsurfer Blackthornone is correct about the metallic flakes not spreading out evenly, thus causing an off color. | I wonder where you heard that before. |
06-23-2009, 10:30 PM
#9 | | Senior Member
Originally Posted by ASPHALT ROCKET I wonder where you heard that before.  | A little birdie
06-23-2009, 10:42 PM
#10 | | Senior Member
Originally Posted by Rsurfer I almost got this kit, but decided to do it the old fashion way. I think any chip after filling, sanded and polished should be clear coated. | Yes, but only if the rest of the car is also clear coated. Otherwise, it won't match. In addition, if a car is clear coated, then the level of the color coat touch up must be BELOW the level of the top of the paint, and instead match the level of the rest of the color coat. Otherwise, it will look like there is a little mound of color in the paint.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » March 2010 | | S | M | T | W | T | F | S | | 28 |
| | 28 |
| 1 | 2 | 3 | » Car Care Brands | | | |
