Just got a 2005 20' Center Console boat. I dont think it was ever put under a shelter, or ever seen a wax or a brush since 2005, so needless to say, it is extremely faded and nasty.
Here is where the problems start. I had the dealership compound the fiberglass parts of the boat for me figuring I could just finish up polishing and waxing. Well, I picked the boat up, and while it looks better, its not perfect.
So since I was at the marine store, I picked up Meguiars Oxidation Remover and Boat Polish. Figured that the oxidation remover would, well, remove the oxidation, and the polish would replace the oils in the fiberglass creating a nice shine. So I start off on the boat with the oxidation remover on a wool pad on the rotary at 1500rpms. Right off the bat, I know this will be hard and with terrible results. I then used the polish hoping it would create that "wet" shine. No, did basically nothing. The fiberglass is getting clean, and it does shine more than in the picture, but it's not perfect. It's extremely hazy and not "crisp" looking. I thought it would be the wool pad not creating the finish I wanted, but when I switched to a lo-pro 5.5" ccs pad, same results.
I know this can be made better, just not sure where to start off. What have you boat guys done to create the results? Maybe i'm just asking to much of the fiberglass and it's as good as it will get.
