car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
» Official Detail Fest 2010 Information Thread!!
» Current Poll
How do you prefer your information?
Paper Handbook - 24.77%
27 Votes
DVD - 11.93%
13 Votes
Digital PDF Download - 63.30%
69 Votes
Total Votes: 109
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 02-19-2009, 07:06 PM   #1
Member
Question on Claying & Polishing
Hi all, I'm new to this forum.
This might be a simple question but....
If I determine a car needs claying but also decide I need to do some polishing with my Flex 3401 for swirls and light scratches should I still clay it first.
For polish with the Flex I have Meguiar's M205.
Will the polishing effectively do the same as the claying in addition to the normal polishing or is the claying still a needed prior step.
I don't mind doing the extra step but also just don't want to take the time doing it if it 's redundant with the polishing.
Depending on the answer for that question, same question pertains if I need more correction and use the Megs M105 compound. Is the M105 enough to pull the contaminants out or is claying still needed?
Thanks for any help
BarryK is offline
Old 02-19-2009, 07:13 PM   #2
Moderator
killrwheels@autogeek's Avatar
Re: Question on Claying & Polishing
claying is a valid step prior to polishing and yes most do or need to do both.
killrwheels@autogeek is offline
Old 02-19-2009, 07:13 PM   #3
No matter what polish you use you will still need to clay the paint first (assuming the car needs it). Clay will pull out contaminents in the paint that a polish will not. I would pick up some M105 or some Menzerna polishes to use before 205. 205 is a very light polish.
sal329 is offline
Old 02-19-2009, 07:14 PM   #4
Good question... When applying the 205, what pad should you use?
hawkman is offline
Old 02-19-2009, 07:17 PM   #5
nitro78's Avatar
the process is wash, clay, polish, protect. yes always clay before polishing. the reason being is lets say some tar was on the paint and you polished it out but where did the tar go? right onto the pad and if there was some sand or grit in that tar you are rubbing it directly into your paint repeatedly. in essence you just made your polisher a sander. a clean surface is very important before polishing.
nitro78 is offline
Old 02-19-2009, 07:25 PM   #6
Member
ok, thanks all. I figured the claying was still needed first but just wanted to make sure.
Sal, I have the M105 also but it's listed as a very heavy cut so I figured unless the finish was really bad I wouldn't need it all that often. Am I wrong? Should I use the M105 for most scratch removals, not just the worst ones, and use the M205 as a finishing polish only?
Amy, I was thinking the same thing, that any grit or whatever that got pulled out could cause more harm if it wasn't clayed first but not being 100% sure I figured I'd ask.
BarryK is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
polishing white paint question gkcomp22 Auto Detailing 101 3 04-18-2008 09:40 AM
Claying vs. Polishing YankeeFan Auto Detailing 101 27 01-18-2008 12:12 AM
Question about hand polishing makdaddy626 Auto Detailing 101 2 01-15-2008 04:39 PM
CLaying Question... roadrunner1659 Auto Detailing 101 2 12-19-2007 05:46 PM
polishing and sealant question chrisbothwell Auto Detailing 101 2 10-16-2007 02:54 PM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
