| New Menerna Polish (Power Finish (PO203S) Power Finish (PO203S) - (M) this is a a one-step scratch remover polish that will remove 2500 grit, cut 3.0- gloss 3.0, Slightly more abrasive then PO 106 but produces a burnished finish (for black or dark coloured paint surfaces use as part of a duel level foam pad / polish system PO 85 RD 3.01 Super Intensive Polish) 1500 RPM - primed LC Orange / Green (mid range, high density foam (60 PPI) medium abrasive cutting action) or a White primed (softer less dense foam (70 PPI) with a light abrasive cutting action)
* Cut is between SIP and 106
See also Polishing - Menzerna Polishes -http://#############.com/index.php5?title=Polishing_-_Menzerna_Polishes
Reason: Up-dated
