car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
» Official Detail Fest 2010 Information Thread!!
Reply
Thread Tools Display Modes
Old 05-04-2008, 02:21 PM   #1
oldmodman's Avatar
Paint Thickness Gauge, Cheapo Harbor Freight First Test Results.
Cliff notes.
It's worth the money and works great for way less money.
I ordered it online since it was not carried in my local Harbor Freight store. It arrived in about a week.
It looks like a generic remote reading temp gauge, with different setting buttons.
It has a trigger for on-off and take a reading.
On the side it has a backlight button, cal (or calibrate) button. Up and down buttons for changing the calibration. And a button to toggle between inch and metric. The inch readings are in thousands of an inch and tenths of a thousandth. The metric is in microns and if much more useful since it reads in thousandths of a millimeter, a much smaller measurement.
Before using the gauge you must calibrate it. You take a reading of a round metal disc that is provided with the gauge, then zero the gauge with the up and down buttons. Then you take another reading of the metal plate but with the test strip between the gauge and the plate. And you use the up and down buttons to make the meter read exactly what is printed on the test strip. Then you are ready to use the gauge.
The first car I tested it on was my 1992 Ford Explorer. I got reading of 112 microns on the hood, 83 on the roof, and 221 on the new paint on the repaired drivers door. I know that the door was re-skinned so I know that it has only new paint on it. Just goes to show you how thin the paint build is on factory paint. I tested several other cars with similar results.
Now for the interesting part.
I got out my test hood, sandpaper, spray bottle of water, rubber sanding blocks, Makita rotary, heavy wool pad, and Meguiars #84 cutting compound and went to work.
I started by taking ten measurements at various places on the hood. I got readings that were very consistent. 127 down to 114 microns.
After sanding for appx one hundred strokes, back and forth with 1500 grit paper and water. the readings were 123 down to 109. All the shiny texture was gone and the hood was ready for the 2500 grit to remove the "heavy" scratching from the 1500.
Same process with the 2500 except it took around two hundred strokes before I was satisfied. The post sanding measurements were 119 down to 107.
The I hit it with the wool pad and compound, only another micron was removed. Then just for the fun of it I used a finishing foam pad and Menzerna Nano and NO change in thickness could be measured.
If all the published reports about clearcoat thickness have been accurate the with a total of 9 microns being removed (from this test hood). This amount of removal is consistent with published, allowable limits for clearcoat removal of 25% of average thickness. I would advise anyone read this tutorial on paint thickness
Automotive Paint Thickness Gages
before ANY sanding projects. As has been used in many legal disclaimers "YOUR RESULTS MAY VARY".
In conclusion, this cheapo gauge is absolutely worth the money. It could help prevent you from ruining your finish. As an example, I might be willing to attempt wet sanding my repainted door, a little less comfortable trying it on my hood, but absolutely NOT on my roof. Think of it this way. Would you rather suffer with a little bit of a scratch remaining after a modest sanding and polishing job, or would you prefer to have to pay for a repaint because you absolutely HAD to get every bit of that scratch out?
oldmodman is offline
Old 05-04-2008, 02:25 PM   #2
Re: Paint Thickness Gauge, Cheapo Harbor Freight First Test Results.
nice write up... the one i found only reads 0-40 mil... can you pm me the link to the one ur looking at?
__________________
AJ Auto Detail, LLC
AjNavo61490 is offline
Old 05-04-2008, 02:35 PM   #3
budman3's Avatar
Very thorough review, thank you very much! A lot of people were weary that the accuracy of the gauge isn't very good compared to other gauges. For example, you take one reading at is says 100 microns but you read the exact same spot again and it reads 97 or 103 (+/- 3%). But for the money it is a great way to give you an idea of your paint thickness. Do you know of anyone in your area that has a more expensive gauge which you can make a comparison with?? That'd be the ideal test -- if they both show the same results on the same spot then this is a great deal...
Do you have to recalibrate it every time you use it? Or is it a one time deal? How long do you think the batteries will last? Thanks!
budman3 is offline
Old 05-04-2008, 02:49 PM   #4
oldmodman's Avatar
Quote:
That was something that I should have mentioned. I found that once you calibrate it, it held cal throughout the day. I did re-calibrate it each time I took it out of the toolbox. I never checked it from one day to the next to see if the measurement would remain the same. But on the first day that I used it I went back to the same spot on my Explorer and re-took a reading and it was always the exact same measurement. I had made a small square of tape on the hood and wrote each reading on the tape after it took it. And they were all the same over the five hour test.
As to battery life wasn't worried since it uses a readily available 9volt battery. I used the gauge for at least three hundred measurements and the battery was still good. And the battery that came with the gauge is a lousy, non alkaline type. I am just going to put a new Duracell in it. I always buy mine at Costco. They sell so many that you know that they are always fresh. And cheap too.
Old 05-04-2008, 02:59 PM   #5
budman3's Avatar
Thanks for the response, very helpful.
budman3 is offline
Old 05-04-2008, 03:08 PM   #6
wheres my response?
__________________
AJ Auto Detail, LLC
Old 05-04-2008, 04:32 PM   #7
budman3's Avatar
Quote:
wheres my response?
I believe that is the one he was using. It measures up to 40 mils which is 1000 um (µm = um) ... the ums (microns) are the metric measurements which are much smaller than mils, which gives better results. People usually measure in ums rather than mils.
Quote:
budman3 is offline
Old 05-04-2008, 06:17 PM   #8
thanks budman
__________________
AJ Auto Detail, LLC
Old 05-04-2008, 09:35 PM   #9
94LT1's Avatar
whats the link to this item because iv been trying to find a paint thickness gauge for awhile now.
__________________
2006 Impreza WRX - EJ255(Very quick 4door)
1994 Firebird - LT1(sold)
1997 GTP - L67(Sold)
94LT1 is offline
Old 05-04-2008, 10:31 PM   #10
oldmodman's Avatar
Sorry about forgetting to include the link.
Harbor Freight Tools - Quality Tools at the Lowest Prices
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Paint thickness gauge? A1monky Auto Detailing 101 5 11-27-2007 03:59 AM
Paint Surface Preparation - TOGWT Auto Detailing 101 9 09-07-2007 10:47 PM
Wet Sanding D&D Auto Detailing Auto Detailing 101 29 07-31-2007 09:40 AM
Paint Thickness Gauges ? Gary Sword Auto Detailing Tools and Accessories 20 04-29-2007 09:31 PM
wax test results are in FloridaNative Auto Detailing 101 23 08-21-2006 02:04 PM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Griots Garage
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
