car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
» Official Detail Fest 2010 Information Thread!!
» Current Poll
How do you prefer your information?
Paper Handbook - 22.40%
28 Votes
DVD - 12.00%
15 Votes
Digital PDF Download - 65.60%
82 Votes
Total Votes: 125
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 05-07-2008, 11:36 AM   #21
Re: Paint Thickness Gauge, Cheapo Harbor Freight First Test Results.
While we're on the subject, I've been looking for a decently priced paint meter for a while now.
My father bought a "fender splendor" seen here:
eBay Motors: LIGHTED Paint Meter Gauge Thickness Tester Car Gage (item 190220454328 end time May-09-08 13:14:12 PDT)
I don't particularly care for it because of it's resolution which is only .5 mil (12.7µm). So you end up seeing usually between 4 and 5 mil when going around an all factory paint car - it's just not that precise in my mind.
The gauge seen here looks pretty good to me (for the price at least):
New Ultrasonic Paint Coating Thickness Meter Gauge - eBay (item 160237010689 end time May-10-08 17:24:12 PDT)
I like the fact that the resolution is 0.1µm (0-99.9 µm) and 1 µm (over 100µm).
What do you guys think?
M3Cosmos is offline
Old 05-31-2008, 07:51 PM   #22
I have a very similar one to that one on order - that one is the CM-8822, but I have the CM-8825 on order. As far as I can tell the main difference is that the one I am getting has internal probes (ferrous & non-ferrous) - no cables at all. I'm a raw beginner at machine polishing (I am going straight to a rotary, aside from a brief stint with a ROB on white paint which I found disappointing) but I'll let you know what I think of it once I receive it. (FWIW)
I have polished part of a test panel and I'm looking forward to measuring how much paint I have removed.
The manufacturer's web site is, I think:
Coleadmeter
Greg.
Skip is offline
Old 06-06-2008, 02:20 AM   #23
Got my Colead Meter CM-8825NF. The operation of the unit seems almost identical to the Harbor Freight model. No trigger though - you place it on the sample and it beeps when it has made a measurement, or there's a continuous mode as well. I prefer the continuous mode, because I can place the unit down as slowly and gently as I like (to avoid scratching), and then wait for the measurement to stabilise. In single measurement mode, it needs to be placed quite "deliberately" on the surface.
Being the dual mode version (Ferrous & non-ferrous), it comes with two calibration substrates. It comes with four different thicknesses of calibration foils as well.
I didn't take any measurements of the area of my test panel that I polished before I did the polishing, but comparing the readings with other parts of the panel, I certainly haven't removed a lot of paint, which is to be expected because I didn't do any heavy compounding.
Trying the non-ferrous (NF) mode, I've discovered that for some panels of my car it gives a vastly different reading to those taken in F mode - circa 80um NF and 140um F. I'm pretty sure the 140um F-mode readings are the correct ones, especially seeing that on some panels it automatically switches to F mode if I had put it in NF mode, and then gives the same 140um reading as the other panels. Now, on my test panel (from the wrecker), it does a similar thing, however in NF mode it produces a much HIGHER reading than F mode - circa 400um NF, and circa 140um F. Again, I suspect that the F reading is the correct one. I assume that it would give valid readings on a panel which really was made of non-ferrous metal, however it's a bit of an inconvenience that it seems that the auto sensing of the material can't be relied on 100%.
I've contacted the supplier about this but in the meantime if anyone else has ever encountered this kind of issue I'd be interested. When I use the calibration substrates, it correctly senses the material and switches to the right mode.
Shipping (from China, I think, to Australia) was very fast indeed - five days from the Ebay transaction having being completed.
Greg.
Skip is offline
Old 06-06-2008, 01:52 PM   #24
Nice read!
alowe is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Paint thickness gauge? A1monky Auto Detailing 101 5 11-27-2007 03:59 AM
Paint Surface Preparation - TOGWT Auto Detailing 101 9 09-07-2007 10:47 PM
Wet Sanding D&D Auto Detailing Auto Detailing 101 29 07-31-2007 09:40 AM
Paint Thickness Gauges ? Gary Sword Auto Detailing Tools and Accessories 20 04-29-2007 09:31 PM
wax test results are in FloridaNative Auto Detailing 101 23 08-21-2006 02:04 PM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Diamondite.com - The Ultimate Glass & Plastic Care Systems
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
