I'll be doing a spring cleaning soon. I'm planning on doing a rinseless wash, the IronX, Nano sponge if necessary, Blackfire AIO, then 845 the next day, or week. Is it ok to IronX each panel, after drying, during the wash process? TIA
I wouldn't use Iron-X unless I planned on flushing the car off with copious amounts of fresh running water. Sent from my iPad using Tapatalk
Cherry on Top Auto Detailing, Fishkill NY https://www.facebook.com/CherryOnTopDetailing
Make sure to THOROUGHLY rinse off the IronX. And I would definitely use the Nanoskin... you might as well after washing and using the IronX.
2022 Jeep Gladiator Rubicon • 2021 Ford Ranger Lariat •2016 Alfa Romeo 4C Spider • 2006 Buell Lightning-Bolt • 2004 Jeep Wrangler Rubicon
I agree with removing any trace of Iron X after using.
Originally Posted by ekennett I wouldn't use Iron-X unless I planned on flushing the car off with copious amounts of fresh running water. OK, would you recommend doing a quick wash after the Iron-X, or just hosing it off ?
I usually pressure wash, then do a waterless. Flush it real good with a hose or pressure wash
