Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree5Likes
Thread: Safest way to remove primer overspray off of rubber trim?
    Sep 2015
    5,239
    Re: Safest way to remove primer overspray off of rubber trim?
    Quote Originally Posted by JKDesign View Post
    After spending many years as a painter and many years as someone who had to clean up the messes left behind by other painters, lacquer thinner never hurt a single rubber seal or weatherstrippping.
    During much of my time as a technician I had the unfortunate task of cleaning/removing an over abundance of overspray from painters/preppers not adequately taping/masking, and cleaning it from areas where it had no right being in the first place.
    Should you always test in an inconspicuous area first to make sure there is no reaction? Yes! Should you follow up with something to treat/seal/condition those seals/weatherstrips afterwords? Absolutely!
    Been in your shoes as well for many years,lacquer thinner on trim will melt the trim and ruin the rubber.Im a lacquer thinner freak but those 2 areas you are asking for trouble in my opinion.
    JKDesign likes this.
    Sep 2015
    5,239
    Op never responded on what type of car and where is the trim located so we can't help further more.
  3. #13
    Sep 2015
    5,239
    Lacquer thinner will remove the top layer of protection on rubber and trim.Even if you condition it will revert back and look horrible.
  4. #14
    Member JKDesign's Avatar
    Oct 2016
    Portland, ME
    40
    Quote Originally Posted by GSKR View Post
    Ah, Yes! You sir are correct! I misread the original post! I went back and re-read it. My apologies.
    To the original poster-DO NOT USE LACQUER THINNER ON EITHER OF THOSE AREAS!!!!!!!!! As GSKR posted, you are asking for trouble.
  1. What can I use to remove Overspray on Trim and rubber areas?
    By 808_detail_nut in forum Ask Mike Phillips your detailing questions!
    Last Post: 03-02-2016, 05:26 PM
  2. Safest way to remove bugs
    By Mercedes350 in forum Ask Mike Phillips your detailing questions!
    Last Post: 05-24-2013, 10:50 AM
  3. How do remove compound/wax from rubber trim and gaskets?
    By Grifftech in forum Auto Detailing 101
    Last Post: 08-13-2012, 11:39 AM
  4. Suburban Rubber Door Trim...Need to remove marks
    By Lilskeezer in forum Auto Detailing 101
    Last Post: 11-24-2009, 11:26 PM
  5. Overspray removal on rubber window trim
    By 321sinned in forum Auto Detailing 101
    Last Post: 10-26-2009, 07:56 AM
» January 2017
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 31 1234
