car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
» Official Detail Fest 2010 Information Thread!!
» Current Poll
How do you prefer your information?
Paper Handbook - 24.55%
27 Votes
DVD - 11.82%
13 Votes
Digital PDF Download - 63.64%
70 Votes
Total Votes: 110
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 11-03-2007, 12:22 AM   #11
D&D Auto Detailing's Avatar
DP is a joke if you're looking for a STRONG wheel cleaner. P21S isnt that strong either, but stronger then DP. From my experience, PB Spray and Rinse is the next step up from P21S. Be sure to follow directions exactly and watch what wheels you use it on.
__________________
D&D Auto Detailing
-Dan
D&D Auto Detailing is offline
Old 11-03-2007, 05:03 AM   #12
BANNED
TOGWT's Avatar
If a wheel cleaner contains Hydrofluoric Acid, it’s not worth the risk to use it! http://www.pbs.org/now/science/chemsafenotes.html
Meguiar's Wheel Brightener (pH 5) is formulated with Hydrofluoric acid that is a solution of hydrogen fluoride in water. It is corrosive, and highly poisonous. Skin contact with concentrated hydrofluoric acid or inhalation of its vapour has caused many serious injuries, even death. Concentrated solutions of hydrofluoric acid pass quickly through the skin and cause deep, painful burns. Dilute solutions also penetrate the skin, but it does not give the immediate burning sensation caused by the concentrated form of the acid, a user may tend to be less aware of the contact with the acid.
It is used to etch glass, but also has the unique ability to dissolve almost all inorganic oxides. In the human body, hydrofluoric acid reacts with calcium and damages nerves, bone, and several organs including the heart and kidneys - http://en.wikipedia.org/####/Hydrofluoric_acid
Note-
a) Acid is highly corrosive! The skull and crossbones warning on an acid label is there for a reason; acids will etch or erode anything in its path, they are also very effective in dissolving metals.
b) The addition of a molecule of water to a chemical compound, without forming any other products is known as hydration (i.e. dilution causes the pH to decrease) But since pH is not a very good indicator of the strength of the acid in every system, this approach won't always produce the desired results. Dilution - adding water to an acid it lowers its pH, i.e. it becomes more acidic; this process is called hydrolysis)
TOGWT is offline
Old 11-03-2007, 05:08 AM   #13
BANNED
TOGWT's Avatar
Alternative products –
P21S Gel or Liquid Wheel Surface Cleaner (Green) originally developed in 1976 by a German chemist, a water-based, (non-acid) detergent that provides terrific cleaning and guarantees not to damage painted, clear-coated, or anodized wheels -
P21S Gel Wheel Surface Cleaner (422, Red) – manufacturers approved way to remove corrosive brake dust and road grime from alloy wheels. Safe, pH controlled, formula is guaranteed not to harm any type of road wheel, braking system or other automotive surface, works safely and effectively on every type of wheel and coating, removes brake pad adhesive and sequestered metal brake dust safely -
If a wheel cleaner contains Hydrofluoric Acid, it’s not worth the risk to use it! NOW. Science & Health. Formula for Disaster? - Chemical Safety Notes |
A dilution of 4:1 (or any other dilution rate will not make it safer) The addition of a molecule of water to a chemical compound, without forming any other products is known as hydration (i.e. dilution causes the pH to decrease) But since pH is not a very good indicator of the strength of the acid in every system, this approach won't always produce the desired results. Dilution - adding water to an acid it lowers its pH, i.e. it becomes more acidic; this process is called hydrolysis)
TOGWT is offline
Old 11-03-2007, 05:46 AM   #14
Tonya's Avatar
Note-
Holy crap! Thanks for the warning TOGWT! I will stick with my ARO! None for me thank you very much
__________________
Thanks,
Tonya AKA twinkle toes
Even a mistake may turn out to be the one thing necessary to a worthwile achievement - Henry Ford
Tonya is offline
Old 11-03-2007, 07:10 AM   #15
supercharged's Avatar
you get what you pay for. I'd rather use a stronger car wash soap (Citrus Wash-n-Gloss, or NXT), but not acid based wheel cleaner.
__________________
1997 Acura 3.2 TL (sold)
supercharged is offline
Old 11-03-2007, 07:56 AM   #16
Moderator
killrwheels@autogeek's Avatar
Having used the Poorboys extensively when it was first released, I would never go any harsher personally. It truly is a Spray/Rinse product but you must follow the directions first including wetting wheels prior to spraying.
killrwheels@autogeek is offline
Old 11-03-2007, 08:50 AM   #17
trhland's Avatar
corrosive and acidic wheel cleaners are what most detailers use. because they work fast and clean good . but the long term affects are bad. for example i used to use a pro all purpose cleaner on my dash board in my dumptruck for years because thats what its ment for . but recently the color is coming off and peeling. not good. and if you read the label it says for professional use only !!! thats why !! live and learn
__________________
names tom i live in nj with my wife and my daughter samantha born 8/23/06 shes so awesome .we love her so much!
trhland is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
New Product Abbreviation Chart sparkie Auto Detailing University 17 01-21-2010 01:22 PM
Can we post more details? Black Diamond Auto Detailing University 20 01-14-2010 11:00 AM
Product Review: P21S gel wheel cleaner. supercharged Auto Detailing 101 14 04-10-2009 02:41 PM
Some information on pH and wheel cleaners Thejoyofdriving Auto Detailing University 19 09-14-2007 01:19 AM
Looking for a strong safe wheel cleaner FMINUS Auto Detailing 101 20 06-26-2007 09:37 PM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Pinnacle XMT Series
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
