What happened to the paint here?
My thinking was to wetsand it
Re: What happened to the paint here?
Kind of hard to tell from the picture. Do you have any information on the history of the paint?
Definitely original paint, was neglected and sent throug the swirl o matic plenty of times. 2006 Ford Mustang with 120k miles. Its on both sides where the door meets the fender.
Ok, I don't know what we're looking at. Paint chips, that spot that could be a different color or could be a reflection, what?
It's the reflection of the swirl o matic brushes.
If you are wanting an approval,
from someone on the AGO forum,
for you to go ahead and wet-sand
original OEM applied paint---that's
been through the torment that you
listed above---Well: you won't be
getting it from me!!
Not sure how to make it more clear. That dull spot is not a reflection.
Paints not in as bad shape anymore. I wouldn't know how else to get rid of whatever that is
Best bet is to look at the spot under a microscope to make sure it's not some sort of paint failure. Also measure the film build of the paint on the spot that is dull compared to the surrounding areas to make sure it isn't dull due to missing clear coat.
Simple way would be to take a white towel and white compound and gently rub the area and make sure there is no paint transfer. If there is paint transfer the problem area cannot be fixed by sanding, polishing, or waxing.
By pxc132 in forum Ask your detailing questions!
Last Post: 08-03-2014, 10:03 PM
By Dr.K in forum Ask your detailing questions!
Last Post: 06-30-2014, 03:44 PM
By b0b in forum Ask your detailing questions!
Last Post: 06-11-2013, 03:39 PM
By Grifftech in forum Off-Topic
Last Post: 03-16-2012, 02:16 PM
By Ohio Detailing in forum Ask your detailing questions!
Last Post: 06-20-2010, 01:23 PM
