| Help with XMT
I've recently started caring for my cars properly(i.e. wash with DP Autobath instead of Dawn. My truck has a ton of light scrathes and spiderwebbing. I currently use a UDM with XMT products however try as I might I cannot remove all of the marks.
The process I have tried is start with 1) XMT 3 on a yellow pad, 2) XMT 1 on a white pad, 3) XMT 360 on a white pad, 4) XMT Glaze on a gray pad.
Before I started the paint had a hazy look, and once I went over with the process above that was gone but some scratches and spiderwebbing was still there.
At first I thought that I wasn't working in the products enough but I re-watched the videos and I'm doing that part right. I also thought that the scratches were too deep, but they cannot be felt so they should come out.
Is it possible that I need to go to XMT 4?
Thanks in advance for any help.
