Re: Why is FG400 doing this to me?
Or even switch to a foam pad for a trial run to see if its the same results
Originally Posted by Nick@Autogeek
Make sure you're cleaning the pad frequently, and do not apply too much product to the pad.
You might also want to slow your speed down just a tad.
Originally Posted by HUMP DIESEL
The diminishing abrasives in the FG400 clog the MF pads really fast. You have to clean them often. Also, the heat can be a problem, and not ambient heat, but the pad heat. Try to ease up on the pressure and let the pad and the compound do the work.
HUMP
I concur with the above 2
1) Work clean (clean pad often)
2) Don't oversaturate the pad with products
3) Don't "cook" the product by working at high speeds and for too long, or by driving the pad in the panel
4) A little extra moisture on the pad may help the work time.
As previously stated ambient temp and % humidity will allow you more or less time to work. You just have to adjust the technique
I blow out the pad after ever section pass. I try and use less product, trial and error, same thing. I just switched to a new pad, same thing. I use no pressure and the machine on 4.5, same thing. It's so weird that it only happens on the rupes. My griots 3inch I don't have this issue.
Are you using a mf pad on the GG3?
Yes, Meg's micro cutting pad.
I would have to say that the DAT technology in Menzerna products do not play well with mf pads combined with the large stroke machines.
It does fine coupled with mf pads on 8mm throw machines but I dont think it behaves properly on that larger throw.
I remember having this issue with the 21, although I don't remember which compound(s) or polish(s) it was. I chalked it up to the long throw of the 21 because changing products, not technique, reduced or eliminated the dusting.
If you have a shorter throw machine, try that. Or, try another pad material. Good luck.
Just like Nick said. Keep the pads clean and I wouldn't go past speed 4. Ideally working between 3-3.5 The MF discs were not designed to be used at high speed for any machine, much less a large orbit da.
By Bicycle in forum Auto Detailing 101
Last Post: 05-14-2017, 08:49 PM
By Justin at Final Inspection in forum Auto Detailing 101
Last Post: 01-18-2015, 10:29 PM
By sansa in forum Auto Detailing 101
Last Post: 03-31-2014, 10:37 AM
By FFguy808 in forum Show N' Shine
Last Post: 02-28-2014, 11:39 PM
By luv a shine in forum Product Reviews
Last Post: 02-27-2014, 08:05 PM
25 | 26 | 27 | 28 | 29 |
