wolfgang steps.
I am about to dive into the DA world and am going to try and stick with one brand of product for my paint correction, cleaning,and sealing needs. I have a 4 year old truck, 1 year old car and a 1 month old car so I know each will require different applications.
After watching your video with Bruno (awesome btw) and reading till I pass out each night, the steps seem clear and you have a pretty good post somewhere I found laying out that you typically go with the swirl remover, FG, and Sealer for less than perfect paints, and the ppe and Sealer or a wax for good to perfect paint like my new car. Acurate so far?
My question is, after I do these steps for example, TSR, FG, and Swal the 1 year old car, or PPE and seal the new car, what product do you use the next time your ready to wax/seal again?
so for the next 3 to 4 months of washing do you recommend their spray sealant after each wash?
For my mian question....Now 4 months later when I'm ready for another coat of waxing/sealing, do you repeat the first process above of either TSR, FG, and Seal or PPE and seal or do you go straight to the deep gloss seal as the only step a few different times to build up protection?
Side question, do you alays use microfiber towels to remove all these WG products or do you ever machine them off after application?
I hope that isn't too confusing....I am about to buy either a Porter cable or Griots with wolfgang products so trying to make sure I'm eating close to understanding. Thanks so much....
Re: wolfgang steps.
Out of all the DVD's we've made I see the most compliments for the DVD Bruno and I made.
Wolfgang Concours Series Instructional How-To DVD
That's a compliment too.... when a forum has lots of helpful information that keeps people glued to their computer it's called sticky, as in you're stuck to the forum.
Yes.
Except if you're going to invest the time to machine apply "something" to a car's paint you might as well apply a fine cut polish instead of a paint cleaner as you'll get more benefits and great looking results for the same time, energy and effort.
I think I explained that this morning in this thread....
http://www.autogeekonline.net/forum/...g-new-car.html
Good question.
For me, again... if I'm going to invest the time and energy into machine applying "something" to a car then instead of applying a chemical only paint cleaner I'm going to apply a fine cut polish.
Both will clean the paint surface and remove old wax as well as road grime but with the fine cut polish not only will I clean the surface but I will also remove fine swirls and scratches which are inevitable when you drive the car daily.
Yes. Build a collection of high quality microfiber towels. More on this later....
For my main question....
If the car is a daily driver you want to do "something" to clean the paint otherwise if you only apply a NON-CLEANING wax or sealant you will be SEALING in road grime which is an oily dirt film that clouds the paint with a gray/black film.
See this article...
Road Film - If you drive your car in the rain your car has road film
Side question, do you always use microfiber towels to remove all these WG products or do you ever machine them off after application?
You always wipe compounds, polishes and paint cleaners off by hand.
I also answered this question in this thread this morning...
I hope that isn't too confusing....I am about to buy either a Porter cable or Griot's with Wolfgang products so trying to make sure I'm eating close to understanding.
Thanks so much....
Not confusing at all.
One thing I'll point out for your benefit.... when interaction on a "forum" you'll get more answers and better answers if you start by only asking 2-3 questions and then ask more later.
The reason why is because when you ask a lot of questions it tends to make otherwise really helpful people shy away because it can get complicated and time consuming to "type" out answers.
If you look above at how I used the multi-quote feature in vBulletin to answer your questions as it makes it easy for everyone to read and follow the interactions, i.e. question/answer question/answer.
Some people don't know how to do this...
Re: wolfgang steps.
This is great information. I have plenty to read today and will reply with any questions. Thank you for the feedback around forum etiquette as well. I did get a touch carried away.
Two questions I have right away to clarify the above quote:
- When you say fine cut polish, it sounds like that is not what Wolfgangs PPE is. Does wolfgang have such a polish?
- In between polishing and sealing is it ok to use spray sealants after each wash or will that "seal in road grime as well" Looking to extend the sealer and machine job as long as possible.
Thank you again for your much appreciated and respected knowledge.
Re: wolfgang steps.
Question 1B from my recent reply may be do you reccomend going with say Pinnacle per your polishing a new car thread. I am hoping to stick with all one brand to make it easy.
I wanted to edit and add this to recent reply but I dont see an edit button.
Re: wolfgang steps.
Either Pinnacle or Wolfgang are both excellent brands, that are easy to use and deliver great results.
Re: wolfgang steps.
The Wolfgang Paint Polish Enhancer is a non-abrasive paint cleaner. It's not a fine cut or any cut polish.
Good question... the road grime builds up over time as the oily dirt "impacts" onto or into the paint and 100% of it doesn't always wash off. At least that's my theory or otherwise how does paint become stained.
So washing helps of course but again... over time, the paint on "daily drivers" becomes stained.
That's why, periodically you want to polish the paint. It cleans the paint down to a fresh base while also removing normal fine swirls and scratches.
But "yes" do use a spray sealant or spray wax in-between these "maintenance polishing" detail days.
Just always paying it forward...
Re: wolfgang steps.
So to reiterate. When I do not need to remove swirls and instead of doing a PPE and Sealant like the wolfgang Bruno video, it will be more bang for more buck to do a Fine cut polish then a sealant. And the FG from Wolfgang is their Fine Cut Polish or do you recommend something different?
Lastly, so it sounds like you do at least a fine cut polish before ever doing a machine sealant every time? Correct?
I have a suntek clear film on the hood of the new car from day one. Per recommendations on the forum thats why I am sticking to sealants so I can use one type of product to seal the whole car as opposed to wax part of it and seal part of it. I am wondering if I should keep the machine away from the clear bra however and apply this all by hand. Do all these techniques apply to the clear film (fine cut polish, sealant, etc)? I plan to do an opticoat on it soon as well, same question?
I think Im close to out of questions for now I have read all the great articles you posted above. Good thing I am working from home today
Assuming I have everything correct above, looks like I will be doing some more shopping tonight. My two bucket system/doley and tons of product is on the way.
By Rifay in forum Ask your detailing questions!
Last Post: 05-11-2016, 10:26 PM
By Supergus1 in forum Auto Detailing 101
Last Post: 04-06-2015, 02:37 PM
By Regency in forum Auto Detailing 101
Last Post: 01-19-2013, 11:44 AM
By BobbyG in forum Off-Topic
Last Post: 01-06-2012, 12:20 PM
By SilverBullet_01 in forum Auto Detailing 101
Last Post: 03-18-2010, 01:29 AM
25 | 26 | 27 | 28 | 29 |
