I just replied to that thread and I'll stand by my comment made in post #11 on page 2 and my new post #63 on page 7
My first answer in that thread is a form of presenting ideas in their extreme which helps sometimes on discussion forums because there's always a segment of members that take everything to extremes...
So to quote myself,
That's a reply to this question,
Does Claying Really Remove Wax?
And while everyone can discuss and disect the idea into enternety, here's was my reply to my good friend Mikejl's conclusion,
Makes sense.
Of course the huge variables here are,
- Downward pressure
- Number of passes
- Thoroughness of claying over each square inch being clayed
- Aggressiveness of the clay
- Lubricity of the clay lube
I'm a big fan of keeping things simple but I notice the trend for at least a segment of online enthusiasts is to take things that are very simple and over complicate them.
Scenario I
If you use a medium to aggressive clay bar with firm downward pressure for a dozen passes over a section about 12" square and you do this thoroughly with a normal spray detailer, say Quik Detailer, at a minimum the wax or sealant coating will be compromised and if it's my car it will be compromised enough that I"m going to add a fresh coat of wax or paint sealant.
Scenario II
If you use an Ultra Fine Clay with very light pressure for just a few passes to say you made a few passes over a section about 12" square using a high lubricity detailer like Last Touch
NOT diluted, then at a minimum, the wax or paint sealant will be compromised enough that afterwards I'm going to re-apply a fresh coat of wax or paint sealant to that area.
The argument could be made in the last scenario that not enough wax or paint sealant would be removed to make a difference and if that's what a person thinks then I'm okay with that, detailing is so subjective.
Where the rubber meets the road...
But in either scenario, if it's
my car that's being clayed, I'm going to re-apply a fresh coat of wax or paint sealant and that's the only scenario that matters... at least to me...
Another aspect of detailing discussion forums is that members will discuss and dissect a topic to death until everyone has their say and everyone's made up their mind. That's what makes a
public discussion forum a
public discussion forum.
Cyberfun in the Cyberworld!
