Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > Ask the Expert featuring Mike Phillips
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 09-30-2012, 05:40 AM   #1
KBsCTS's Avatar
Clear coated whels
Cleaning my Camaro after a ride up to Erie Pa and when I got to the wheels I found some scratches . What can I use to get rid of these.
I believe these are polished clear coated wheels. I own a 2010 Camaro SS
Thanks !!!!!!
__________________
Find what you like and use it alot ....
KBsCTS is offline
Old 09-30-2012, 06:56 AM   #2
BobbyG's Avatar
Re: Clear coated whels
You can use just about any product you'd use on the body panels. Compounds such as Meguiar's M105, Menzerna Power Gloss and a Mothers Power Ball or similar device work very well...
__________________
BobbyG is online now
Old 09-30-2012, 07:11 AM   #3
pro 4x's Avatar
treat them like your paint.
How To Clean and Polish Clear Coated Wheels
__________________
2012 NISSAN XTERRA PRO-4X
PROTECTED AND MAINTAINED WITH THE PRIMA HYDRO LINE
pro 4x is offline
Old 10-01-2012, 11:33 AM   #4
ihaveacamaro's Avatar
Do you have the RS package? If you do, you have Midnight Silver Painted 20 inch rims. There is no clearcoat on this.
If you have the RS package and upgraded rims, you have polished aluminum 20 inch rims.
If you have an SS, with no RS package or upgraded rims, I believe you have alloy 20 inch rims, but I'm not 100% sure like I am with the above two situations.
So... which rims do you have?
ihaveacamaro is online now
Old 10-02-2012, 06:47 AM   #5
KBsCTS's Avatar
I own a 2010 2SS with 20 inch wheels
__________________
KBsCTS is offline
Old 10-02-2012, 09:12 AM   #6
Quote:
do you have the RS package or did you pay the option for polished wheels?
There are 3 different kinds of 20 inch wheels for the Camaro. All are the same style, but each has a different finish.
Old 10-02-2012, 11:15 AM   #7
stibuki's Avatar
The polished 20" are like most current larger sized GM polished/cleared rims. They didn't do a very good job polishing them out. You didn't say if you see fine uniform scratches on all your rims. If so I would bet it's under the clear coat. Not that noticeable except under certain lighting conditions. Almost every set I have seen has this issue, some more than others. If they are random then most likely it's surface and as said above treat them like paint.
stibuki is offline
Old 10-03-2012, 04:55 AM   #8
KBsCTS's Avatar
THANKS FOR INFO !!!!!
__________________
KBsCTS is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
so i screwed up my clear coat repair, thoughts? timaishu Auto Detailing 101 29 01-12-2012 11:59 AM
What it means to remove swirls, scratches and water spots out of automotive clear coats Mike.Phillips@Autogeek Hot topics and Frequently asked questions 9 01-06-2011 11:19 AM
Help with Clear Coat failure (pictures included!) Wills.WindowsAndWheels Auto Detailing 101 8 09-16-2010 12:24 PM
Distinguishing clear coated rims cadd Auto Detailing 101 9 09-07-2010 09:19 PM
Headlamp Lens Sealant? alexjn1 Auto Detailing 101 9 09-08-2009 03:02 AM
» May 2013
» Car Care Brands
