Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > Ask the Expert featuring Mike Phillips
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 09-25-2012, 08:25 AM   #1
SPIROS ANTONIOU's Avatar
3000grit i cant remove it easily
Hey mike ,,,
I sand an audi hood with mirka 3000 and after the first hit with mf and d300 i was still seeing some tiny sand circles under lighting .. I then try with surbufs and m101 and the circles left..
My question what went wrong .. the sand pad was perfectly fit in the Machine ,speed was 1,5 and no pressure also too many water.. one Friend told me that my backing plate was't too soft for sanding ..
SPIROS ANTONIOU is offline
Old 09-25-2012, 08:34 AM   #2
Re: 3000grit i cant remove it easily
I'm not Mike, but I'll take a stab at it
Did you use a interface pad? I'm thinking you might have applied to much pressure
Flash Gordon is offline
Old 09-25-2012, 08:38 AM   #3
Hello Flash Gordon ,i dont mind at all, all opinions are welcome..i used this
Old 09-25-2012, 08:40 AM   #4
I had the same issue with DA and MF/D300, I dropped my speed down to 2 on the Griots and everything was cleared up.
Best to use foam interface for sanding.
Wheelzntoys is offline
Old 09-25-2012, 08:41 AM   #5
Those are nice disks. I use the same, but I also use an interface pad to ad cushion
I'll try and find a link to the interface pads
Old 09-25-2012, 08:41 AM   #6
smack's Avatar
+1 If you didnt use a interface pad the hook and loop material on the backing plate probably made contact through the sanding disc with the material you were sanding.
__________________
Practice dosent make perfect, the dedication to achieve pefection makes perfect. "Smack" (aka Mike)
smack is offline
Old 09-25-2012, 08:45 AM   #7
Quote:
i was used only mirka to the backing plate ..Do you quys believe that is this the problem?
Old 09-25-2012, 08:49 AM   #8
Found them
3M Hookit 6 Inch Soft Interface Pad, 3M 05777 interface pad, disc interface pad
Thanks Smack! I was thinking the same thing
Old 09-25-2012, 08:50 AM   #9
smack's Avatar
Even with the 3000 paper with foam behind it is still not enough cushion to keep the actual backing plate from making contact. You can see that the foam is pretty much the same depth as the hook and loop material on the plate but once you add some downward pressure the foam on the sanding disc collapses and the hooks on the backing plate will make contact with the surface beneath it. Thats why you need a foam interface pad between the sandpaper and backing plate.
__________________
smack is offline
Old 09-25-2012, 08:51 AM   #10
Found them
thanks gordon ,, is there any smaller ,for exaple 3 inches??
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints Mike.Phillips@Autogeek Ask the Expert featuring Mike Phillips 85 05-18-2013 02:48 PM
The Definitive How-To Article for Removing Swirls, Scratches and Water Spots Using a Porter Cable 7424XP, G110v2 or Griot's Garage Polisher Mike.Phillips@Autogeek Tricks, Tips and Techniques 47 09-19-2012 09:13 AM
Traditional Orbital Buffer aka The Wax Spreader Mike.Phillips@Autogeek Hot topics and Frequently asked questions 11 06-19-2012 08:16 AM
My Neighbors Third Cousins Daughter..... Flash Gordon Wet-Sanding, Cutting & Buffing 34 07-15-2011 10:10 AM
What it means to remove swirls, scratches and water spots out of automotive clear coats Mike.Phillips@Autogeek Hot topics and Frequently asked questions 9 01-06-2011 11:19 AM
» May 2013
» Car Care Brands
