Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > Ask the Expert featuring Mike Phillips
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 09-06-2012, 09:32 AM   #1
Opti-Coat high spot fix?
I just attempted my first OC install over the Labor Day weekend, and I botched a few panels. Despite having researched the tricks to applying OC, and *thinking* I was being careful, I still managed to leave some high spots. I understand that high spots have to be polished.
Questions:
1) I'm assuming I need to buff the OC all the way off the affected areas, or is it possible to fix them without a total re-do? I'm pretty sure it's the former but looking for confirmation of this.
1a) If it's possible to fix the high spots, what pad and polish combo would give the best chance for success on a DA?
2) If I buff the OC all the way off the affected areas, can I mask a perimeter around the affected area and buff that portion of the panel, or do I need to re-do the entire panel? The vehicle is a Subaru BRZ, and some panels are rather complex. For example, the quarter panels wrap around the door to form the A pillar on top and the rocker panel on the bottom.
3) Is there a benefit to polishing the areas now, when OC has only been applied within the past few days, or wait longer? What timeframe is proper?
thanks!
coredump4 is offline
Old 09-06-2012, 10:25 PM   #2
Optimum Product Support
Chris@Optimum's Avatar
Re: Opti-Coat high spot fix?
As long as you're not too aggressive, you won't have to reapply. Since the coating isnt fully hardened, a pass or two with Optimum Finish, Polish II, GPS, or Poli-Seal on a soft finishing pad will likely remove the excess easily. As long as you stop when it clears up...you will still have a normal thickness of the coating intact.
__________________
Chris@Optimum is offline
Old 09-14-2012, 08:41 AM   #3
Chris,
Thanks for describing a technique to improve this situation. I attempted my repair roughly 3 days after initial application. I used a CCS blue pad with Polish II very gently at low speed (~1500 OPMs on the 7424) with some success. I'd say about 40% of where I polished worked as you described. The other 60% had no hope: by the time the high spots weren't visible, too much product had been removed. This was verified at the next washing, as it's really obvious where there's OC and where there is not.
So now the big question is, can I re-apply OC to the areas where it's missing? I think this should be OK, though I'm not sure how it will look at the juncture of an area that already has OC and one where it's being re-applied. Any further thoughts are appreciated!
thanks!
Old 09-14-2012, 09:32 AM   #4
tuscarora dave's Avatar
Quote:
Originally Posted by coredump4 View Post
Chris,
thanks!
Is this your Subaru or is it a customer's car? If it's your personal vehicle, then it seems you may be in a position to do some testing with Opti-Coat spot repair/re-application. If you felt so inclined to do such testing and report your findings back to the forums, you could really help a lot of folks who seemingly are posting up initial application issues with Opti-Coat. Give and take is the name of the game on these forums. If your testing was successful, you could really offer a great contribution to the forum.
I'm subscribing to this thread as I am interested in how this turns out for you.
tuscarora dave is offline
Old 09-14-2012, 03:15 PM   #5
It is my own car. I will likely try to do a spot repair this weekend; at this point, I have nothing to lose because if the repair fails, I'm re-doing the whole panel anyway. I will report back...
Old 03-27-2013, 04:28 PM   #6
I never reported back, but I did re-apply OC to some areas. It seemed to apply just fine, and didn't cause any problems when I overlapped with the areas with OC on them. I'm still not a true OC believer, however. It's about to start warming up here in the mid-Atlantic region, and I'll assess whether OC has remained on my vehicle through the winter. I'm not entirely sure that it has.
One trick I've learned: if you're applying OC in your home garage, like I am, it's going to be nearly impossible to have enough light to properly apply OC. My recommendation is to try one of these white LED work lights:
Rakuten.com - 2 - Pack - 27 LED Superbright Worklight/Flashlight w/ Built-In Hook Hanger & Magnet (Batteries Included)
Portable Super Bright 27 LED Magnetic Hanging Hook Flashlight Spot Light Camping - Newegg.com
(I actually bought mine at my local 7-Eleven!)
These helped a ton in finding OC high spots. Basically, after applying a section of OC, trace the entire section with this light and you will catch your high spots. There are wand versions of these worklights that I'm sure work well too.
I'll add more information in a few weeks, after I've had more time to do a proper springtime assessment of the vehicle.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Opti coat on thin paint PoorOwner Auto Detailing 101 13 07-29-2012 10:30 PM
The practical differences between a single stage paints and clear coat paints Mike.Phillips@Autogeek Hot topics and Frequently asked questions 7 05-01-2012 08:47 AM
Opti Coat Questions! Help Needed! wildjyoung Tricks, Tips and Techniques 1 02-02-2012 09:51 AM
Which pre wax cleaner/paint prep would you use prior to opti coat application unclestu Auto Detailing University 5 01-07-2012 03:37 AM
New Car Opti Coat 2.0 detail - 2011 Camry SE Matt S. Show N' Shine 24 05-01-2011 04:32 PM
» June 2013
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
» Car Care Brands
DP American Made Car Care Products
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
