Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > Ask the Expert featuring Mike Phillips
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 08-20-2012, 01:04 PM   #11
tuscarora dave's Avatar
Re: Black Paint
Quote:
Originally Posted by Paul Lonergan View Post
From the creator of the "How to use a Porter Cable" Mike Phillips now presents... How to use a toothbrush for that showroom shine!
Including ...
2 glass wash
Clay barring your teeth
Single stage or enamel coating?
Masking off
Hand or machine polishing?
Priming your brush
Correct brushing techniques
Recognising and dealing with hard water and mineral deposits
Chemical washes
Working clean
False teeth ... The absolute tooth
And many more!
Sent from my iPhone using AG Online
LOL!! That's creative and comical!!
tuscarora dave is offline
Old 08-20-2012, 02:01 PM   #12
Member
siberianrunner's Avatar
Re: Black Paint
Hey, also working with black and dark blue paint here in Minnesota. Last fall I did a complete clean up and correction on both cars followed with a coat of Klasse High Gloss Sealant Glaze then topped it with Pinnacle Souveran paste wax. The Klasse lasted through the winter and well into the spring before I finally cleaned it off for the cars spring cleaning. Not the last word in gloss factor but the Klasse HGSG wins my endurance prize. Added two coats this year, seems to have picked up the gloss a bit but then I also put a bit more into the prep this year.
siberianrunner is offline
Old 08-21-2012, 06:59 AM   #13
Member
Re: Black Paint
So I should wash the car again to get rid of the oily haze?
bus3 is offline
Old 08-21-2012, 07:18 AM   #14
Director of Training
Mike.Phillips@Autogeek's Avatar
Re: Black Paint
Quote:
Have tried misting on a little spray detailer and then wiping with a slowly and gently with a clean, soft microfiber towel?
Like this?
The Final Wipe
After all the work is done, when it’s time to give the paint the final wipe-down before you stand back and say to yourself it is finished, and then you take your pride and joy for a spin around the block or turn the keys back over to the owner, you usually want and need to give the paint a final wipe-down to insure you didn’t miss any spots and to remove any trace residues off the paint that can stand out like a sore thumb in the right light at the right angle that will so easily distract everyone’s attention from the work of art you’ve created.
This technique can often times help you to remove any stubborn streaks or uneven looking areas on the paint, and it’s exactly opposite of what I’ve often seen enthusiasts and detailers do my entire car detailing life.
The Technique
The technique is to wipe the paint down slowly using your best, premium quality microfiber polishing cloth using gentle, even pressure. Fold your polishing cloth 4-ways to provide plenty of cushion to help spread out the pressure from your hand as best as you can over the face of the folded microfiber.
Fold your microfiber polishing cloth to create plenty of cushion to help spread out the pressure from your hand and to give you 8 dedicated wiping sides.
The secret to this technique is purposefully moving your hand and wiping cloth s-l-o-w-l-y over the paint, not like a spastic crazy guy moving his hand at light-speed over the surface.
Is so and that's not working then sure, go ahead and wash the car.
Mike.Phillips@Autogeek is online now
Old 08-21-2012, 07:50 AM   #15
Member
Re: Black Paint
I will mist it with wg instant detail spritz if that doesnt work then I will wash the car.
Thank you everyone for the great advice!!!!
bus3 is offline
Old 08-21-2012, 08:43 AM   #16
S2K
S2K's Avatar
Re: Black Paint
I used Liquid Souveran on my Honda once and did not like the results either. It was just like you said, oily and streaky. I really like Blackfire Wet Diamond and Fuzion, both super easy to use and Great results!!!
S2K is offline
Old 08-21-2012, 04:57 PM   #17
Member
Re: Black Paint
Quote:
I will have to try one of those. I threw away the Souveran.
bus3 is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Miscible and Immiscible - Wax and Paint Sealant Bonding Mike.Phillips@Autogeek Hot topics and Frequently asked questions 24 03-01-2013 06:11 AM
The Definitive How-To Article for Removing Swirls, Scratches and Water Spots Using a Porter Cable 7424XP, G110v2 or Griot's Garage Polisher Mike.Phillips@Autogeek Tricks, Tips and Techniques 47 09-19-2012 09:13 AM
Wetsanding - Fresh Paint vs Factory Paint Mike.Phillips@Autogeek Wet-Sanding, Cutting & Buffing 10 05-08-2012 01:19 PM
Sacrificial Barrier Coating = The purpose of a wax or synthetic paint sealant Mike.Phillips@Autogeek Hot topics and Frequently asked questions 10 03-20-2012 08:20 AM
How much product do you use with DA? (megs 105/205/po85rd) estcstm3 Ask the Expert featuring Mike Phillips 12 06-06-2010 01:06 PM
» May 2013
» Car Care Brands
